Question about Kitchen Ranges
BT2450 OVEN NOT HOT FAN /GRILL BOTTOM HEATER ALL WORKING BUT WHEN USING FAN ASSISTED OVEN NOT HEATING UP
  • 262 Answers
If you are refering to the convetion fan with the heater around it. then you could have a bad convetion heating element or the relay on the control board could be bad or a burnt off wire.
Posted on Sep 08, 2010
  • 5 more comments
  • bdoyle873 Sep 08, 2010
    THE FAN IS WORKING WITH THE GRILL ITS THE ACTUAL OVEN NOT HEATING ITS A BEAUMATICBT2450 BOTTOM HEATER WORKING JUS NOT OVEN
Wont get hot grill works think the element has
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
May 04, 2010 | Ovens
Fan forced heat not working
If it is an electrically heated fan oven, then it sounds like the oven element is not working.
This is usually located at the rear rof the oven behind a removeable cover.
Hope this helps.
Dec 05, 2009 | Ovens
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Zanussi Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 03, 2008 | Kitchen Ranges
Our Delonghi DFS090S0 oven has stopped heating up. The fan is still working but no temperature.
My grill is not working no heat, hot air is running normally. what may be the reason that my grill heater could be blown, if so, how to replace it?
Mar 30, 2008 | Kitchen Ranges
Kitchen Ranges Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
