Question about GPS
Each time when i started my c200k, srs signt will be light on at display screen in front of driver, sometimes some othrs light will be crazy, on and off repeatedly and sometimes aircon and tail lights stopped immedietly during driving
Hi, you will probably find that this is an indication that your alternator is beginning to fail and will require replacement. Happy spending!
Posted on Oct 31, 2010
Toyota Echo 2003 SRS light with ABS light blinking instead of Seat Belt Light
When you sit in the seat and put the seat belt on does everything work ok . If so look to the fact that you are required to wear a seat belt and the fact that you are not might be the problem.
Mar 09, 2014 | Cars & Trucks
I have 1992 honda accord srs light is on & sometimes d4 on?
d4 is engine control module and has it got both driver and passenger airbag fitted or just driver. as yours is on the change over
Dec 22, 2011 | 1992 Honda Accord
No Screen display on tecra m3 laptop
if you go into safe mode (F8) on boot-up, does the graphics show up?? If so, it's the graphics board/chip on the MB. I have one and have the same problem - no amount of loading drivers, re-install BIOS, etc. would help. sometimes it works, but most times when you start up, shows the Toshiba logo, and once windows starts, goes to a black screen.
Oct 02, 2009 | Toshiba (K000823110) Motherboard
SRS light
Here's a quick check list for most common cost of SRS / Air bag problem.
Dirty contacts on driver and passenger seat belt buckles
Dirty contacts on seat belt connectors (under seats)
Dirty contacts on driver and passenger sides weight sensors (under seat)
Seat covers
Weight on passenger seat
(Example: grocery package trigger SRS / Air Bag light on the way home.)
I recommend you to pass an vacuum over the contacts and use CRC electronic parts cleaner to rule out connectivity problem.
I DO NOT recommend disconnecting the negative battery connector to clean the code(s).
Without the code(s) the dealer will takes "BILLABLE" time to reproduce the problem.
Please rate my answer if it is useful to you.
Cheers,
Mustgo
Aug 19, 2009 | 2000 Acura TL
Fuel gauge malfunction in 2000 Mercedes S500
you have a problem with your gearbox thermo cutout £65.-- repair
Aug 13, 2009 | 2000 Mercedes-Benz S-Class
SRS LIGHT ON, C200K MFG 2001
perhaps there is a problem with your airbags. take to mb dealer
May 26, 2009 | 2001 Mercedes-Benz C-Class
My 2003 ford expo has a constant airbag light lit after starting the veh. I have a new sensor, can't figure out were 2put it.. Please help.
first, you need to read the Lamp Fault Code, LFC from the flashing light. Here's how:
Lamp Fault Codes
When the restraints control module (RCM) detects a system fault, it will cause the air bag indicator to flash a coded sequence: a lamp fault code (LFC). The code is two digits. The first digit is flashed with a 0.5 second interval between pulses. There is a 2 second pause before the second digit is flashed, which also has a 0.5 second interval between pulses. There is a 5 second pause between each display of an LFC.
Each LFC is flashed five times after which the air bag indictor will remain lit for the remainder of the key-on cycle. If there are multiple LFCs, each LFC will flash in order of priority.
The fault could be in the air bag circuits, the canopy circuits, the pretensioner circuit on the seat belts, etc.
Report back with code.
here's some of system.
SECTION 501-20B: Supplemental Restraint System 2003 Expedition/Navigator Workshop Manual
DESCRIPTION AND OPERATION Air Bag and Safety Belt Pretensioner Supplemental Restraint System (SRS) The air bag supplemental restraint system (SRS) is designed to provide increased collision protection for front seat and second row outboard occupants in addition to that provided by the three-point safety belt system. Safety belt use is necessary to obtain the best occupant protection and to receive the full advantage of the SRS.
This vehicle line contains dual stage deployment (advanced restraint system) driver and front passenger air bag modules. These vehicles can also be equipped with optional safety canopies that deploy from the A-pillar to the C-pillar upon a side impact or if a rollover condition is detected. If equipped with safety canopies, a unique restraints control module (RCM) is used.
See the following illustration for deployable component location.
Air Bag and Safety Belt Pretensioner Supplemental Restraint System (SRS) Deployable Components a55c8c5.gif Item Part Number Description 1 611D10 Passenger air bag module 2 042D94 Passenger side safety canopy module 3 042D95 Driver side safety canopy module 4 61203 Driver safety belt buckle and pretensioner 5 043B13 Driver air bag module 6 14A664 Clockspring 7 61202 Passenger safety belt buckle and pretensioner
Item Part Number Description 1 14B321 Restraints control module (RCM) 2 14B345 Second row, C-pillar side impact sensor 3 14B345 Second row, C-pillar side impact sensor 4 14B416 Driver seat track position sensor 5 14B345 Front row, driver door, side impact sensor 6 14B006 Front impact severity sensor 7 14B345 Front row, passenger door, side impact sensor
Apr 23, 2009 | 1997 Ford Expedition
Srs idiot light stays on after vehicle start
Check under the drivers and passengers front seat for electrical cables. sometimes the connections can get disturbed by feet or items that have rolled under the seats (specially if you have kids)making a bad connection of the cables
Hope this helps
Feb 09, 2009 | 2002 Land Rover Freelander
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
