Question about Poly-Planar POLYPLANAR Platinum Series Flush Mount Speakers 6 12" FlushMount TwoWay Speakers
I have a MRD 60 polyplanar cd unit. The cd does not eject when I push the eject button . Nothin happens when I reset the unit. It also does not recognize that there is a CD inside the unit.
2007 azera cd won't play & willnot eject or load cd's
Odds are the electronics inside the audio unit (head) have malfunctioned. There is only one way to check/verify this. The passenger compartment Fuse/Relay box has a power bar (shunt fuse) yellow in color. Pull this fuse out (not all the way out). Wait 60 seconds then reinsert (push back in) to reset the Audio (Radio) unit. Recheck the CD functions (load/eject). If the same problem recurs, then it's the audio unit/head which has malfunctioned. The typical repair is replace the audio unit.
Sep 10, 2011 | 2006 Hyundai Azera
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
CDs are jammed. will not eject or play. i have a bose front loader 6 cd changer. this unit came in a infinity 2003. Someone told it happens when the batery is diconnected while cd's are in. How can I...
Hello
I can help you with this problem. All you need to do is to force eject the trey which is hilding the cd's. This will cause no damage, the hole is made for this purpose.
First you need to locate a small hole near the eject button.
Now you need to push a pin into the hole untill you feel resistance.
While holding the pin securely gently pull out the trey.
You should be able to recover your cd now and your player should work perfectly again. Please rate this.
Best regards
Sep 30, 2009 | Bose Audio Players & Recorders
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Mecha error
Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
Feb 03, 2007 | Kenwood KVT-717DVD Car DVD Player
CD do not eject
I have the same prob with mine right now and thats why I came here was to find the manual. In the manual it states that that when something like this happens you need to hold two buttons for a few seconds and what it does is it resets the cpu in the deck. I had to do it before and yes I was kind of leary of the solution also but IT WORKED!! Now I'll have to dig before posting this otherwise I didnt just create a common solution I talked about it. Ok while holding power/ATT press eject for more than two seconds, and it says careful not to drop the cd~~~DAAA Or to reset the unit: While holding SEL (select) press power/ATT for more than two seconds and that will reset the unit to factory defaults. And this was actually from my owners manual of which I found...
May 26, 2006 | Jwin JCCD200 CD Player
Poly-Planar POLYPLANAR Platinum Series Flush Mount Speakers 6 12" FlushMount TwoWay Speakers Logo
44 people viewed this question
Top Poly-Planar Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Poly-Planar Boating Expert? Answer questions, earn points and help others
