Question about Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le
It will not rotate when you push any button on the remote
My remote is not working
You have to hook up roku box BEFORE YOU PUT IN BATTERIES IN remote.Make sure batteries are making a good connection try rotating batteries or try new batteries.Some ROKU models have a button in remote next to batteries. this has to pushed to connect to ROKU box.
Jan 01, 2016 | Roku 3
How to switch from tv to dvd
Your DVD will be (or should be) connected to your TV using either HDMI cable, Component Cables + Audio, Composite Video + Audio or other A/V connection. Your TV remote will have an input selector that switched the source signal within your TV. This can also be called source selector. In any case, you need to push this button on the remote to rotate through sources (if only one button) or push the button labeled DVD, for instance to select the DVD inputs. Please note that only one type of connection should be used such as HDMI or Component, but not both.
Apr 03, 2015 | Samsung Televison & Video
How to enter radio code,which i have,into Renault radio fitted to a T35 van year 2001it has a steering wheel remote OE
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
Jul 08, 2011 | Car Audio & Video
How to put a laguna radoi code in
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ============================================================
Jun 14, 2011 | Car Audio & Video
Im trying to find out how to enter the radio code for a factory fitted stereo. A family member has just been given a renault 19 1994/1995. We have the code but, no user manual for stereo. Any help would...
May 28, 2011 | Car Audio & Video
We understand that your problem is: my 2002 laguna stereo plays for about 2 minutes but bleeps every 5 seconds and then displays 0000. The sticker on top of the stereo says radio 2607 but when i put...
your correct code is 8410
Code Entry Instructions
=================================== PHILIPS RENAULT CODEENTRY INSTRUCTIONS FOR CARS WITH A STEERING WHEEL REMOTE CONTROL (Note :If you don`t have the [ ¬ ]button then push the thumbwheel in andsome will have an [ A¬ ] button ) Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for thecorrect first digit Press the [ ¬] button then rotate the thumb wheel for thecorrect second digit Press the [ ¬] button then rotate the thumb wheel for thecorrect third digit Press the [ ¬] button then rotate the thumb wheel for thecorrect fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to storethe code IF THERE IS NOSTEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digitto be displayed Press the Third Preset Button repeatedly for 3rd digit to bedisplayed Press the FourthPreset Button repeatedly for 4th digitto be displayed Then press and HOLD Preset button 6 for 10 seconds to store your code (Note :Some radios use Preset Button 5 to store the code ) ============================================================
Apr 25, 2011 | Car Audio & Video
My heli always rotated at the left side.....although i push the right button it still rotated at the left side.....and it becomes hardly rotated when it start to fly.....hope u have the solution for this...
check that the fan on its tail is working fine ???
either it is rotating slow or very fast and is not being controlled by commands sent by your remote control.....
or may be the blades, either of them may be, got damaged some how and are not providing enough force to push the air and keep heli stable...
kindly check these few thing and InshaAllah your problem will be solved.. :)
best of luck...
Mar 10, 2011 | RC Helicopter With 3 Channel Remote...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Menu rotates
Had the same problem with the Mitsubishi ws 48511 model. A solution posted in FixYa worked great and might be worth trying as they have very similar electronics and panels -- did you check to make sure that one of the front panel buttons isn't stuck in the depressed postition? For me, the device menu kept cycling and remote wouldn't work. Sure enough, the button was stuck pushed in. It was hard to even notice, but took little effort to get it free. Good luck.
Nov 13, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Logo
22 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
