Question about KitchenAid KSRG25FKSS Side by Side Refrigerator
Kitchenaid model Ksrg22fkss03 does not cool. I can here the unit run and click every few minutes. What do I need to replace?
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Why is my True THAC-48 unit is not cooling?
need more info. is the condensor fan running? if not thermostat problem.if it is , is the compressor running or just makes a one time click a few seconds after plugged in? (after unplugged five minutes)... if this is the case it probably needs a new start capacitor (170 uf)..if the compressor is running the larger tube going in the commpressor should be cool about 40-50 after a few minutes .. if not then it is low on refrigerant..R-134 after 1995. or R-12 for older models.. now you also have inside fans and thermo buttons that can not be working.
Nov 09, 2013 | True THAC-48 48in Horizontal Air Curtain...
My KitchenAid refrigerator is not cooling (including freezer). The problem started after a power outage during the night. Periodically the refrigerator makes a sound of a click with a buzz, another...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I have a KitchenAid KSRS251 side-by-side refridgerator that is clicking every couple of minutes and the you can hear an motor or something run for a few seconds. The freezer is defrosting and I think...
heatman101
Mar 18, 2011 | KitchenAid Superba KSRG25FK Side by Side...
My refrigerator is a Kitchenaid KSRG25FKSS05 and still runs but not cooling. I hear some kind of relay click and then click again after about 10 seconds. Then I don't hear it click again for a few minutes....
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Nov 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Clicking from underneath
you need a new relay and overload on the com pressor
goto www3.sears.com type in your model number
look for compressor or controls
on the compressor itself you will see the overload box
you might need both the relay and overload id replace both anyway
Oct 08, 2009 | KitchenAid KSRG25FKSS Side by Side...
Kichenaid refrig not keeping cold
Need to have someone with multimeter check the compressor and the capacitor. May be the start capacitor not allowing the compressor to run or continue running. Let me know, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerator and freezer not cooling properly
you have a deffective compressor the humming that your hearing or the clicking is the relay on the compressor trying to start the unit, the compressor is stuck and cannot start, leaving it unplugged lets the compressor cool down, but as it tries to recool the unit it gets orerheaated again, thus the bad compressor
Apr 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
148 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
