Question about Cameras
Hi, I dropped my fujifilm finepix JX530 camera. And now keeps saying 'Turn camera off and back on again' I've tried everything but still it wont work normaly. please help!
    Brigadier General:
  • 11,967 Answers
Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 08, 2010
  • guv999 Jun 17, 2011
    Hi - Just to clarify I have experienced this issue with the JX530 and upon calling Fuji Tech support was advised that this is a known design flaw with this model and is very sensitive. They have repaired the camera free of charge under warrenty
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Jan 01, 2016 | FUJIFILM Cameras
Tells me to turn off and back on
Fujifilm finepix s2980 says turn camera off and turn it back on. Sounds silly but someone on here said drop camera from about 2to 3 foot on to carpeted ground, and mine started working again. something to do with lens gears not engaging. and the impact was enough to ironically make it re-engage. Thanks just saved £55 cost of camera and proberly more if I was to sent it for repair.
Nov 06, 2013 | Fuji FinePix S2980 Digital Camera
My camera is zooming in and one edge of the lenses is higher than the other one
Due to regular dropping it internal parts seem to have become loose and thus are not in control. Try getting it checked it at the service center to change the loose parts
May 16, 2017 | Fuji Cameras
Need owners manual for finepix jx530
Hi Tracy,
Here's the user manual in pdf.
Hope this helps.Thanks!
Dec 28, 2011 | FUJIFILM Cameras
Dropped it and now it wont read sd card
Try removing the batteries and the SD card and then the putting them back again.
Check the SD card for possible damages.
If problem persists,try another SD card.
Nov 05, 2011 | FUJIFILM Finepix S2100HD Digital Camera
My fujifilm finepix JX530 camera wont focus. I tried everything on the menu but still it wont focus. please help i just got it today!
If this is a brand new camera and it won't focus and you've read the manual and followed the directions, then you should return the camera.
Aug 06, 2010 | Cameras
Olympus Picture Card showing 'card error'
I rang Fujifilm and they said that the finepix A345 can only take up to 1gig cards. So have to take my 2gig back which sux. The say Olympus cards may not be able to be read by the camera. So will be taking my camera with me when i exchange my 2 gig.
Feb 01, 2009 | Fuji FinePix A345 Digital Camera
Fujifilm digital camera finepix a 500
Check ou this link: http:// www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics (cleaning the lens, replacing the batteries, etc.), try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Apr 30, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Cameras Logo
1,215 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
