Question about Bosch Washing Machines
Ive got a bosch wfb2004 washer, everytime i do a wash water comes out of the bottom of the draw and runs down the front of washer. How can i fix this ?
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
vest6
  • 196 Answers
SOURCE: washing machine
Depending on the age of the unit:
Possible minor leak at the pump.
Possible leak at the spin bearing/boot seal.
Posted on Dec 30, 2007
  • 1314 Answers
SOURCE: wfb2004 bosch front loading washing machine
maybe your water is hotter
  • 135 Answers
SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Posted on Apr 08, 2008
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric...
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric conditioner section is remaining full of water
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch washing machine is leaving sludge like marks on my clothes. Ran the machine at 90 degrees with soap but no load. Didn't solve the problem. Any ideas?
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Aug 26, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Apr 29, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFB2004 Washing Machine with Very Hot Water Washing
check to see if the hoses are on the wrong valves like hot connected to the cold valve
Jun 01, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
