Question about Toshiba Televison & Video
I have a Toshiba rear projection tv model 55A60A. The color on the screen doesn't match up. you'll see wording and images and above them will appear the same wording in red. it's like a ghost image offset. I've have the tv for about 10 years and it just started happening. trying to determine if ther's a cost effective fix or just time to get a new tv. to big to have to bring it somewhere would have to find someone to do a house call. any suggestions what it might be?
  • ibejd3 Sep 08, 2010
    I looked at the repair kit and think I can do this myself. Do I need anything other then the kit and a soldering iron? for example do I need a digital multimeter once I get in there and start to do the repair?
    Rylee. Thanks for the help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 08, 2010
  • Rylee Smith
    Rylee Smith Sep 08, 2010
    Yes right a part from this you'll need the voltmeter. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi Mode; 53UDX10B
http://serviceman.site88.net/index.htm
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
Tv picture
Does the image appear to be 3D? Let me know as it sounds like convergence issues. Is there anyway you can post a picture of what the screen looks like?
May 17, 2008 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50in rear projection. Mod# 55A60A
convergence ic 's are bad need to remove and replace chips, need soldering skills, do not attempt if you are not good at soldering and desoldering
May 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Televison & Video Logo
544 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
