Question about KLH HTA-9706 System
Hi i have a older jvc stereo and i have klh audio system model 9706 satellite and i do not know how to do the wiring i can get three spks workig but thats it can u help me do the wireing my jvc has 4 spk outlets do u have a manul for this
  • 35 Answers
You can use 4 speakers. Connect 2 speakers to the A system of the JVC and the other 2 to the B system. Then select in JVC the A+B speakers position. As your receiver is stereo, this is the way you could best distribute the sound. However, if you have only 3 speakers, it would be dangerous to try wiring the third one without changing the whole impedance. So you may use 2 speakers.
Posted on Sep 08, 2010
I have a pair of KLH Audio Systems speakers, model number C130B. They came (used) with no wires. Can anyone tell me how to connect them to a stereo? Thank you for any help.
Far as I know, you only have two wire posts on each speaker. Stereos have two wires out for each speaker. Doesn't matter which wire goes to which post so long as you do it the same for each speaker so they will be in phase. I use red as + and black as neg.
Dec 08, 2014 | Cars & Trucks
How do i wire a aftermarket cd changer to a factory gm car stereo pontiac sunfire 2002
It will all depend what specific system you have in the car and how it is wired. There were a few audio system options in that model of Pontiacs including the Monsoon audio system. Based on what you get today in the aftermarket like JVC there will be wiring changes required including the connectors that link the car sound systems to it.
Please see the pontiac 2002 manual to check which system your model has. Page 3-7 onwards.
http://www.vadengmpp.com/owners-manual/pontiac/2002-Pontiac-Sunfire.pdf
Also some information on which JVC you were planning to fit in.
A typical one would look like this .
http://resources.jvc.com/Resources/00/00/94/MA110Bien.pdf
Sep 06, 2014 | JVC Car Audio & Video
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
One of my stereo klh 915 b shows a short at the input terminal with ani wires connectedv to it
Is this an active speaker system? How do you know there is a short at the input of the speaker?
Dec 13, 2010 | KLH 915 Main / Stereo Speaker
I have a KLH SW-90 amp. When I plug in the RCA plugs I don't get any sound to the Satelight speakers. Is this a sub amp? Do I need to hook up the high input wires to make the satelight speakers work?
I have the same amp. there a two ways to use it: The phono plug inputs are low level, are for use as an amplifier only, and their only output is the subwoofer output. In this case, any stereo satellite speakers would be driven directly from your stereo amp.
The high level inputs are meant to be driven as the same as speakers from your stereo amp. A circuit inside samples the bass and directs it to the sub amp and output. this same circut passes unamplified outputs to the satellite outputs. PM me at moestevens@cox.net if you need further info.
Oct 24, 2010 | KLH Audio Players & Recorders
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
Hooking up a klh PSW8-100 sub wofer
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com -- it has a blog about wiring your home audio system and the cables that you will need.
Hopefully this helps! Good Luck!
Dannyboy!
Sep 20, 2008 | Audio Players & Recorders
Protecked mode?!
when i had this problem my wires were touching the case. other times the wires were touching eachother
Mar 23, 2008 | JVC MX-KB30 CD Shelf System
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
KLH HTA-9706 System Logo
150 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
