Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have a Poulan rider mower and the V-belt broke. I'vbeen to the dealers 5 times ad none of the belts fit properly. I need the length and product number. Also the number of the headlight bulbs. Is there a place I can gto to find parts and numbers for my mower. Thanks for u're time and help inthis matter.
  • 3,083 Answers
Here is a belt that Sears carries for this mower, perhaps it would work:
http://www.sears.com/shc/s/p_10153_12605_07124115000P?vName=Lawn+&sName=Tractor+Belts&cName=TractorAttachments&srccode=cii_10043468&cpncode=21-75038018-2&sid=IDx20070921x00003c
You might go by Sears Service Dept. or call them, and see if they have your headlight bulbs- they probably do.
Here is Sears Direct web page, just enter your model number:
http://www.searspartsdirect.com/partsdirect/index.action?psid=58710556&sid=PSx20071217x00001a&OVMTC=Broad&site=&creative=3873690564&OVKEY=poulan%20tractor%20part
This site also has tractor parts:
http://www.tractorhouse.com/listings/parts/Search.asp?pdcl=1
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 08, 2010
Fit belt for product no 96011 0219 00
Bring your old belt to your local mower shop. They can match up a new one for you
Jan 25, 2015 | Husqvarna Garden
What size deck belt does poulan 38 inch cut 15.5 engine
I would make a drawing of the way the belt is routed on the mower and then take the belt off the mower and either measure the length of the belt or take it to a lawn shop and purchase a new belt or if you know the width and length of the belt you can order one from V Belt supply on line I have found them to have good pricing.
Jul 03, 2014 | Poulan Garden
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What is the actual drive belt size in inches for 300ex
IT is likely that the proper part number is listed on a tag under the hood. If not you can get the units model and serial number off of a tag under the seat and your local AYP dealer can get you the proper belt.
I suggest getting the proper belt. First, there is not much cost difference. Second the ' v' on the OEM belt is different from an automotive belt and will last longer. Lastly, AYP lengths are usually a bit off like 1/2 x 95 5/8 so the even numbered automotive belts wont be the correct length.
Nov 19, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Finding replacement belt from UK for McCulloch hornet ride on mower
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Hope this helps someone.
Aug 01, 2012 | Garden
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
What is the deck drive belt length for this mower deck model# PD15538LT 38" Poulan riding mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Sep 10, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
It keeps eating drive belts! It looks like the pulleys are not parallel. Can you align them? It appears to be spring loaded
Either the belt you are using is not the correct lenght and width, or one of your pulleys is worn out. Make sure that you are using the correct belt. Poulan mowers (made by AYP) will typically use a fractional length belt...meaning that you have to buy a Poulan belt to go on it. With the proper belt and pulleys, the front drive pulley should be level and the belt pattern should not contact anything other than the pulleys.
Aug 30, 2010 | Poulan Pro " Pro" Self Propelled Mower
I need a belt for th scott 20hp 46" mower model # 2046H. Where can I get it besides a dealer?
You can order them here. If you have the part number it is better (same site) but if no part number
http://www.jackssmallengines.com/find_belts.cfm
(EXAMPLES only... not your actual part number)
The part number for a 5/8 belt is
258077 258 = 5/8 inch belt 077 = 77 inches long. This would be for a 5/8"W X 77L belt.
If you know the length of your belt you can call around town to larger automotive supply stores and ask for the 258___ belt by length.
Mar 30, 2010 | Garden
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
103 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
