Question about Sony Cyber-shot DSC-N2 Digital Camera
My camera DSC-N2 keeps sayin turn of and switch on again...n the lens is stuk in d barrel..wt do id o ?i can view the pix ive taken ..but cant clik any pix nor video
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 08, 2010
When I push the power button, "access" appears on
Hi, this is what we call a lens malfunction. Usually caused by debris getting into the lens such as
sand, etc... or the lens has suffered some kind of Jolt. The only lasting resolution is to
have the lens repaired or replaced.
Feb 01, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
When turning on it says, "Access" then "Turn the Power off and on Again"? Video and camera will not work, but can see pics taken? The camera is: Sony Cybershot DSC-N2 10.1MP
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 30, 2011 | Sony Cybershot DSC-T77 Digital Camera
Respected sir when i on my sony cybershot dsc-n2 ..... access.......turn the power off and on again.... please help
Hello
Regards
Andrea
Nov 05, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My sony cybershot dsc-n2 fell out of my pocket at my daughters birthday party...since then it won't turn on. I tried taking the battery out and the memory card but still nothing...any suggestions?
Hello
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 12, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My DSC N2 keeps saying "turn camera off and on again". It will not shoot pictures.
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Sep 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
The lens shutter on my Sony cyber shot DSC-N2 will not open. It extends out but the shutter remains closed. Any help?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Aug 23, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My Sony Cybershot DSC-N2 lens are not working properly and the message on the screen is "turn the power off and on again" Please help me.... Thanks
Hello
Regards
Andrea
Jul 20, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
When I turn it on the software keep telling me to switch off and on again.
It is lens mechanism problem and system control deos not get reset signal from lens mechanism.
Need to replace lens assembly. Qualified camera tech will replace it.
Oct 01, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Turn off and on again.
you should have dropped your camera down hard. you should replace your lens array from the nearest sony service center. it costs about 60$.
Jun 11, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Lens
No live view or black pictures, but readable menus means a bad CCD or less likely, possible shutter on cameras equipped with one (more scarce on newer digitals)
Apr 22, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
181 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
