My air conditioner won't stop running. The fan won't stop on the upstairs unit unless we remove the thermostat from the wall. The condenser runs constantly. It does cool when the thermostat is plugged in. I took at look at the unit and the fan came on, even when I had removed the thermostat. I don't think I have a thermostat issue.
  • 674 Answers
Does the compressor also run constantly? If it does, the problem with the outside unit may be a stuck contactor. You can remove the cover where the power goes into the outside unit and the contactor should be located near there. If it is stuck, turn off the power to the outside unit and tap the contactor to try to free it, depending on how bad the contacts look, or replace the contactor. As for the indoor fan, you could have a bad fan relay, if that is what your unit has, or a bad fan sequencer, which is what some units use. These components will be located in the air handler. Hope this helps. Let me know what you find if this doesn't help and I can offer more advice based on that.
Posted on Sep 08, 2010
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 07, 2016 | Intertherm Heating & Cooling
My A/c won't start
Have an electrician check the capacitor in the unit as the motor will not run if it has failed.
Jun 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Unit for downstairs is running fine, but upstairs unit doesn't want to kick on, but outside unit is running (fairly hot though). Tried to re-set, but "cool" just sits there and flashes on the...
Are you saying you have two HVAC systems or one? If you have two indoor units, you must have two outdoor units. Which outdoor unit is running. You said it is running hot. Assume the fan in running to cool the condenser. If so it should be about 20 degrees warmer than outdoor air. If not maybe you have a dirty condenser coil. Need more information.
Aug 26, 2011 | Carrier 38CKC036 Air Conditioner
A/c will not continue to cool.. Starts fine, runs fine.. but shuts down cooling ( comp shuts off but fan still runs) after anywhere from 5 min to multiple hours. No circuit breakers or fuses blow. CAN...
One amateur test is to place your hand on the compressor and see if it
is too hot to hold your hand on it. You may have a restricted condenser coil
If it is too hot then the condenser coil is restricted inside the unit
if not be sure and clean condenser coils with good coil cleaner.
You can put a fan on the compressor and see if it runs for another test to confirm it
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Dometic Rooftop RV Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Ouside unit runs continuously, even if system is off
the contactor is stuck you might try killing the breaker to the condensing unit if it stops then it is the contactor
Oct 10, 2009 | Heating & Cooling
My ac stops after one hour and yellow and green lights are blinking
How to Check Your Air Conditioner Before Calling... [Edit]
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing the life span of your equipment.
2. Wash your condenser coil regularly. Simply turn off your air conditioner, get a garden hose, and spray the coil using an "up/down" pattern. Be particularly attentive if your condenser is close to a dryer vent, or if your neighborhood is full of cottonwood trees. These two items are "air conditioner killers".
3. Look for ice around your condenser. If there is ice around the copper lines, immediately turn off your air conditioner and call for service.
4. Is the condenser and/or furnace operating at all? If not, check breakers and fuses.
Tips:
1. Maintaining your air conditioner and having it serviced regularly increases the efficiency of your unit, reduces energy usage, and prevents wear and tear on your equipment.
2. These instructions need to be modified slightly for window or "through the wall" type units.
Warnings:
1. Do not attempt any repair work unless you are a licensed heating and air conditioning technician. Most states require a licensed heating and air conditioning contractor to perform any repair work.
2. Do not attempt to add or remove refrigerant from your system unless you are licensed by the EPA. Fines and penalties await
those who tamper with or release refrigerant in an unsafe or unapproved fashion.
3. Do not attempt to diagnose any electrical problem unless you have been properly trained and/or are licensed.
4. Do not immediately assume that if your air conditioner is not working that the thermostat is at fault. Tampering with the thermostat
or is related wiring can cause more problems than you initially started with. If nothing is happening with the thermostat set,
mmediately call for service.
5. Do not bend the "fins" on the outside of the condenser. Make certain to wash the coils in an "up/down" fashion.
6. When in doubt, stop. Immediately call a licensed heating and air conditioning contractor. Did you find this Chapter Helpful? Yes No
Edit this chapter
Jul 22, 2009 | LG Heat cool Window Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Heating & Cooling Logo
605 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
