Question about Lasko 2554 Wind Curve Tower Fan with Fresh Air Ionizer
My lasko mod 2554 fan powers up but the fan will not work. The fan oscilates and the ionizer and timer lights all work.
  • 17,130 Answers
It is possible that the main capacitor is faulty and so the coils is not enerrgised to start.
So check winding and check the capacitor for open.
Test capacitor by charging both the pins to mains voltage and shorting the pins to see if charge is retained.If retained the capacitor is good, if not replace.
Posted on Sep 08, 2010
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Where can I find a motor for a lasko FAN model 2554. Motor number is Decomin 2033014 120V 0.45A Thanks.
No guarantee they would see one, but you could start looking here and see what they have to say.....
http://www.decomin.com/product_1.htm
Sep 17, 2010 | Lasko 2554 42" Wind Curve Fan with remote...
My lasko wind curve 2554 has suddenly developed a steady ticking noise whether it's oscillating or not. I've taken it apart & nothing was caught in the blades. Blew it out & oiled a little at the...
It's probably the motor. I doubt there's anything that can be done besides just live with it if it isn't too loud. If you were a tech guru, you might be able to take the motor apart and do something but otherwise, for us mere mortals, when something this serious goes wrong with something this inexpensive, it's either live with it or junk it and buy a new one.
Jul 10, 2010 | Lasko 2554 WIND CURVE Fan
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Cleaning my 2554
there are 20 screws to take apart the fan.
but try this
something to wedge the blade and blow out the fan. it will work jus the same
Jun 28, 2009 | Lasko 2554 WIND CURVE Fan
Lasko 2554 tower fan
I just replaced the thermal fuse in the motor case. You can find replacements at Radio Shack. http://www.radioshack.com/product/index.jsp?productId=12505747&utm_source=Google&utm_medium=PPC&utm_term=55048814&utm_content=Exact&utm_campaign=PLA&%7bifmobile:ds_dest_url=http%3A%2F%2Fm.radioshack.com%2Fradioshack%2Fproduct%2Fdetail.do%3FitemId%3d12505747%26utm_source%3dGoogle%26utm_medium%3dPPC%26utm_term%3d55048814%26utm_content%3dExact%26utm_campaign%3dPLA%7d&cagpspn=pla&gclid=CIjo_4_ylrkCFUcGKgodMG0AAA&gclsrc=ds.ds
You will need to open the motor case and carefully cut the heat shrink tube off where the red wire connects to the white wire. I do mean carefully, as you don't want to cut the tiny coil wire soldered to the white wire and the thermal fuse. Cut the old one out, leaving some of the old lead to solder the new one too. Be sure to add new heat shrink tube before soldering the new one in so you can get it all back properly. This certainly took some time and patiance but was better than throwing it out and spending another 60 to 70 bucks.
Aug 06, 2008 | Lasko 2554 Wind Curve Tower Fan with Fresh...
Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Jun 08, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Dryers Logo
648 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
