Question about Whirlpool Calypso GVW9959K Top Load Washer
MY CALBRO KEEPS DISPLAYING LD FLASHING CODE. WHAT DOES THIS MEAN.
  • Whirlpool Master
  • 19,396 Answers
LD means long drain, and it is displayed when
First disconnect power, then move the appliance and ensure that the drain hose at the back is not kinked or blocked.
Next step will be removing water from the inside and checking the hose attached to the pump.
In Cabrio the pump is located at the bottom side of the appliance. You will need to move the washer and tilt it forward to reach the pump.Located at the base of the machine on the right hand side.
The pump is connected to two hoses, disconnect both and look for blockage. Ensure that power is not connected and be prepared to collect the water coming from the hose.
Accessing the pump usually solves the problem. If it does not, then the pump must be tested energizing it directly. If the pump is OK, replace the pressure switch that detects when the pump has finished its job.
Here you get all diagrams and parts for your appliance.
Posted on Sep 08, 2010
What does Code LD mean? When it is supposed to spin out, It stops and I get a code LD.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Dec 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does LD mean?
It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 23, 2009 | Washing Machines
My Kenmore Elite keeps flashing LD after I start to wash. Then the machine stops washing. Clothes are not wet, but I heard water going into the machine. How can i fix this?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 27, 2009 | Kenmore Washing Machines
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
May 18, 2009 | Ricoh Aficio 1035 Copier
WHIRLPOOL CABRIO WASHER
LD means long drain and will require a drain pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Whirlpool Calypso GVW9959K Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
