I am not sure if this is a soft or hard failure because my HP Compaq does not display a thing on screen whenever I am trying to turn it on
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Try pressing Function and F5 button.
Posted on Sep 08, 2010
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
My hp Compaq min 110 has a screen display problem, one can turn it on but the screen responds nothing....
If all is normal with an external display, consider replacing the internal display/inverter.
Mar 07, 2016 | HP Computers & Internet
My HP Compaq laptop nw9440 screen gives me white tin lines whenever I powered it on and don't display anything ,I tried removing the memory but still nothing happened
The memory has nothing to do with the display. Most likely it is the inverter board. For the display. They are not expensive an can be put in easily if you can solder. Take it to a repair place an let them look at it to make sure. I have seen the screen fail from crumbs an dirty contacts.
Jan 27, 2016 | HP Computers & Internet
How to restore corrupted BIOS of presario cq60 laptop
Whenever you upgrade the BIOS on your notebook, a copy of the previous version is stored in the HP TOOLS partition of your hard disk drive. Many HP notebook computers have an emergency BIOS recovery feature that allows you to recover and install the last known good version of the BIOS from the hard drive, as long as the hard drive remains functional. This emergency recovery feature is separate from the BIOS and is designed to work in the event of a catastrophic BIOS failure.To recover an earlier version of the BIOS on your notebook:
  1. Turn off the computer.
  2. Plug the notebook into power using the power adapter.
  3. Press and hold the Windows key and the B key down at the same time while the computer is off.
  4. Still pressing those keys, press and hold down the Power button on the notebook for 3 seconds and then release the Power button and the keys. The screen remains blank for about 40 seconds before anything appears on the display. You might also hear beeping sounds. Eventually, an HP BIOS Update screen displays.note.pngNOTE:If the computer fails to display an HP BIOS Update screen, press and hold the Power button for 5 seconds to turn off the computer. Wait 5 seconds and try again. If, after repeated attempts, you cannot open the HP BIOS Update screen, your computer does not support this function or it has a hardware problem that is preventing the tool from opening.Figure 1: HP BIOS Update screenc03376208.jpg
  5. When the BIOS has been recovered, a Continue Startup button displays and timer counts down. You can click Continue Startup to restart the computer or you can allow the timer to reach zero and the computer will restart automatically.Figure 2: HP BIOS Update screenc03376209.jpg
  6. After restoring the BIOS, if the computer repeatedly displays a message that the BIOS has been reset, then perform the steps in HP BIOS Application Selected is Corrupt or Missing .
  7. After restarting, Windows may display a message stating that the computer was improperly shut down or that a boot problem was detected. Read and respond to the screens to continue.
Sep 22, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
Have an hp tc1100 I don't know a lot about computers. I can not get it to stop on the blue screen of death to see what may be the problem. I have tried to photograph so I can read,the most I can get is...
Installing a new BIOS when your laptop is in such an unstable condition, is very dangerous as it may crash during upload and write off the mother board.
Try starting in safe mode and run CHKDSK/F from the start/search box. That will clear any errors on the hard drive. The most blue screen failures are from hard drive errors and memory errors.
Hope that helps.
Feb 02, 2011 | Compaq tc1100 Tablet PC
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
My HP NX 7010 won't start it diplays the hp logo and that it
it might be a hard disk failure or Ram failure check first by changing ram
Feb 19, 2009 | HP Compaq nx7010 Notebook
Blurred display problem
Could you post a picture of the screen?
May 23, 2008 | HP Compaq nx6115 Notebook
Failure is imminent
Bad sectors on a hard disk is an every day thing, the hard drive keeps a bunch of spare sectors and a table to reroute bad sectors to the backups. This warning basically means that you are out of backups, and now you may start losing real data if you do not change the hard disk.
Feb 17, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
