Question about Apple iPhone Smartphone
I dropped my iphone on the ground, it was a mild drop not a very harsh one but my phone battery was almost finished at that time, the red part of the battery was visible for quite sometime. the phone seemed stuck and menu was not visible and only message was visible, i try to send a message to my husband and the msg. sending failed. so i left it for a little while and found it working so i resent the msg. again and it worked. so i kept it on charging and heard strange sounds from inside, sort of buzzing sound. after half an hour of charging i checked my phone and found it not working. i think it is not charging at all and when i charge it i have noticed that the chargers light turns off, the same charger shows the light on, when i charge my ipod.
  • 1 more comment
  • rosymalik Sep 08, 2010
    how to unscrew an iphone?
    if we get a universal charger then no need of changing the port?
  • rosymalik Sep 09, 2010
    i dont even know how to open my iphone for battery replacement. can u guide me how to replace battery in order to check if my phone is working or not.
  • Apple Master
  • 3,866 Answers
Yeah there is a serious issue with the batttery inside when you dropped this phone it could have been a contrubiter to this. obviously the iphone will need to be repaired, opened up and ultimatly battery being replaced.
sorry this happend to you but there is no magic wand here at fixya you next step is the shop.
Posted on Sep 09, 2010
  • 1,555 Answers
When you ipod was dropped the charging point on your ipod became intermittent. For your information your chargers light wents off because it gets a DC voltage back from the charging unit ie your ipod. I will recommend you not (R) not to try to charge your ipod until you have replaced the charging point on your ipod. Take it to a repair shop and get your charging point replaced. Before taking that to repair shop i would suggest you to borrow a charged battery from your friend of the same type and try to switch on your ipod if the ipod is switching on then only go for replacement or else the suspected fault is that the main pcb of your ipod has gone bad and replacing that would be beyond economical repairs (more than 50% cost of a new unit)
    Genius:
  • 1,416 Answers
what this indicate is that the phone has develop a problem from it charging port ,
what you will have to do to fix up this problem is to make a replacement on the changing port ,to get the port you will have to visit any phone technician store around you or at any store at your local area for your phone for easy compatible ,
then follow this instruction to carry out the assignment ,
carefully unscrew (open)the phone from the screw with a phone tools then trace the port to the position of phone change carefully remove it and then repleace the new one(port) you have just gotten at the store
please note this piece of information
make sure that the part (phone charging port i.e the same make and the same side )that you are replace is same with the old one that you are taking out from the phone for easy compatible
or
you get your phone a universal charger easy to use
hope this help?
thank you and thank for using fixya.
Posted on Sep 08, 2010
  • Oloyede Monsuru Sep 11, 2010
    hello,
    Am very sorry for not responding on your comment for some days ,
    please if you did not have the knowledge on how to go about the phone
    i.e the batter carefully take it to a very good phone work shop around to
    avoid more damage on it .
    thank you once again.
Whatsapp error
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
God bless you
Jun 01, 2013 | Nokia X2-01 RED,BLUETOOTH,FM,QWERTY...
Nokia6710c
The iPhone 4 has a well-documented issue regarding its antenna case design that could cause someone to drop a call if they hold the iPhone in a certain way. This problem lies in the design of the phone's hardware, and can not be fixed with any software updates or new parts. There are two solutions to this problem; you may:
  • follow Apple's advice, and not hold the phone in such a way that alters the reception, or
  • put a cover on your iPhone.
Dirty antenna grounds
If your iPhone has been disassembled before, it's possible that finger oils were left on the grounding locations for the Wi-Fi or Bluetooth antennas. These oils will cause grounding issues for the antennas, which could lead to a weak signal or no connectivity at all. Be sure to clean all grounding points with an electronics cleaning solution before reassembling your iPhone to prevent grounding issues.
God bless you
May 24, 2013 | Nokia 6710 Navigator Black 5MP Carl Zeiss...
My phones charge finish quickly. Why
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 17, 2011 | Cell Phones
Dropped my iphone 3G, screen went black with some vertical lines. itunes still recognizes the device, i can still play music (using a speaker/charging cradle remote control)I can still hear SMS alert and...
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
Dec 17, 2009 | Apple iPhone 3G
I dropped my iphone 3g on the ground at about 4 feet. and the screen is super dim. and i can cant see the words. but the phone is still working. the screen is just really dim
Yopu got a problem with your crystal IC for the LCD, it probably mis-aligned from solderd, bring it to a technician andhave them Re-heat the crystal IC at the back of the LCD screen
Nov 09, 2009 | Apple iPhone 3G Premium Polycarbonate Red...
My touch screen won't work after I've dropped it.
Probably damaged or loosened an internal connection. Similar thing happened to me and I needed a new motherboard.
Sep 19, 2009 | Apple iPhone Smartphone
Dropped my iphone and screen went white
Take it to the apple store. Even if it is not under warranty the guys at the genius bar should be able to fix it.
Aug 03, 2009 | Apple iPhone Smartphone
Okay today i dropped iphone on the ground and
You have been dropping your phone so hard that the body cracked. With your second dropping, the circuits may have got disconnected. Take it to your service centre to get it going.
Aug 01, 2009 | Apple iPhone 3G
I dropped my iPhone today - wont charge
After you dropped your iPhone I assume the battery connector to *********** board has moved.  Now you have to open your iPhone which follow link tells you very simply how to do it. and put the connector in to right spot.  Do not be afraid, it is not that difficult to do it but make sure you have the proper tools. I have finished to do that and my iPhone is completely fine.
Good luck!!!
http://www.youtube.com/watch?v=Le_QV2hO024&feature=related
Jun 30, 2009 | Apple iPhone Smartphone
I hear an Echo when I'm using my Iphone
One of the PC magazines did an extensive drop test on the iPhone without breaking it, so your dropping it on the carpet didn't cause the problem. Echos can be caused by communication with the cellular network, so you should verify the problem by trying the phone in your local ATT/Cingular store. You may also experience a time delay that you will notice if you call another phone close by where you can hear the live voice as well as the one on the phone. Both of these problems are found in all cell phones, not just iPhone, BTW.
Jul 22, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
61 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
