Question about Remington Health & Beauty
Replace remington shaver batteries model ms2391
SOURCE: Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Posted on Mar 02, 2008
geokohler
  • 304 Answers
SOURCE: battery replacement
I have the .PDF file from remington for disassembling your shaver for you. Also this model is known for poor battery life and I recommend replacing the NiCd batteries with Lithium Ion batteries of the same size. This will give you much more shave time and 10 time the number of recharge cycles. Post me an E-mail address where you want me to sent the instructions to you or you can just E-mail me and request the instructions and I will attach the .PDF to my reply letter ( geokohler@gmail.com). If you enclose your number I will call you for free and walk you through the process.
I hope you find this information valuable. If you do please take the time to rate this a FixYa. If you ever need my help again post it here and I will be notified of your need for further assistance by E-mail. I do this for a hobby so there will never be a charge.
Sincerely
George
Posted on Jul 28, 2008
ICCeditor
SOURCE: Remington M8221 Help
STEPS
• Thoroughly clean the razor cutter area
• Pull off (straight out) cutters and lay aside
• Release spring clips and remove
• Gently pry up and remove rubber boot
• Pry case open starting at cutter end and bending up toward connector end
• Thoroughly clean razor interior area (blow out)
• Pull up motor and remove black oscillator bars
• Pry up the circuit board by releasing the cutter-end catch using a small tool to push it in while prying gently up on the cutter-end of the board and bending up
• Clean the board and turn it over
• Note battery polarity and mark on board if not present already
• Unsolder the battery tabs using unsolder braid. Be careful not to short the electrical circuitry as the batteries are electrically LIVE at this point.
• Remove the old batteries and fully clean off the circuit board solder-pads using unsolder braid.
• Mark the installation date on the new batteries in a place where it will be visible
• Install new batteries, making sure the polarity is correct (cut the tabs to a correct length if they extend too far through the circuit board)
• Solder the battery tabs being careful not to short the electrical circuitry as the batteries are electrically LIVE at this point
• Re-install the circuit board and other parts following the procedure in the reverse order (be sure to put a soft rubber pad over the motor to hold it firmly in place when the upper case half is snapped in place)
• Before installing the metal retaining clips be sure that the rubber boot is fully free and not pinched between the case halves
• Finalize the assembly by reinstalling the cutters and screen
Posted on Aug 24, 2008
  • 5 Answers
SOURCE: Remington R 9170 shaver
http://www.remington-products.com/manuals/ib_mftitaniumu.pdf
In the PDF instructions it describes how to remove the batteries. The instructions fail to mention that there is a spit of yellow glue that is holding one of the batteries to the curcuit board with a death grip. Undoubtedly, you will have to use a knife, not in the glue, but on the skin of the battery. Pull on the teather wire, and slice the battery skin around the glue.
If after removing the batteries, and you are not thouroughly discusted with the manufacturer, then purchase a couple of AA Ni-cad batteries solder the positive of one battery to the negative of the other. then solder the free positive end to the red wire, and then the blue wire to the free negative end. Then try to remember how to reverse the process and put it back together, without leaving any parts out. ;-)
There is a risk of injury by overheating the battery when soldering. That should be avoidable if you remember how to drop solder. Just like its name, it involves having the wire securely held in place. Then hold solder iron over the wire/battery end. Then take some rosin-core solder and apply the solder to the hot tip. Then make sure the newly melted solder lands on the contact. Keep in place until it cools and holds the wire to the battery.
If you think this is better than writing to Remington complaining that they did not make it easier and use contacts, instead of solder, so we can simply pop in a new set of batteries. Or maybe look at other manufacturers, and see if they are any better.
Posted on Dec 28, 2008
brector3
  • 1600 Answers
SOURCE: rechardable battery . can you tell me how to take
First, remove the foil and cutters. You will then need to gently pry off the rubberized front cover with a small flat screwdriver or similar object. You will then be able to access and remove the two screws at the bottom. You will then need to pop the case apart by carefully inserting a flat screwdriver at the bottom between the AC port and the case. Once you pop it apart you will need to remove the metal clip at the top that so that the case can be fully seperated.
You will then be able to see the batteries.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If this is not something you can do yourself, you might want to consider one of the items below which will give you and easier fix
http://shaveroutlet.com/remington-ms2370-lower-unit-p-208.html
http://shaveroutlet.com/remington-ms2100-lower-unit-p-209.html
Posted on Apr 24, 2010
Testimonial: "thank you this was veryhelpfull great many thanks"
1969 Remington ladies electric razor model Cl how to use it
Women's Shaver Parts' Parts and Accessories ' Remington ...
www.remingtonproducts.com/.../womens/shaverpart...
Remington ProductsRemington women's hair removal replacement parts. Electric shaver parts, wet dry shaver blades, shaver heads and cutters, shaver cords, ... I have a Remington Smooth & Solky Plus Wet/Dry Rechargable Shaver (Model: WDF-5000) and am ...
Women's Electric Shavers - Remington Products
www.remingtonproducts.com/womens/.../wetdrysha...
Remington ProductsRemington Women's Hair Removal Wet Dry Shavers ... Wet/Dry Shavers. Smooth and Silky 4 Blade System Rechargeable Shaver With Almond Oil; $39.99.
Jan 07, 2016 | Remington Health & Beauty
Need a replacement battery for remington ES1000 electric shaver and blades
Unfortunately, blades for this model were discontinued several years ago by the manufacturer and are now impossible to find now.
Batteries can be purchased from shaveroutlet.com. You will need two. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
Sep 22, 2011 | Remington ES-1000 Electric Shaver
I need find battery
You will find the correct battery type for model ES-1000 at shaveroutlet.com. See link below. You will need two
Jan 24, 2011 | Remington ES-1000 Electric Shaver
Te battery will not hold a charge.
Batteries in your shaver model were not designed for replacement. Disassembling the shaver will result in damage to the case as it is glued together.
shaveroutlet.com has a simple and inexpensive solution of replacing the 'lower unit'. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 08, 2010 | Remington Titanium MicroScreen MS3-2700...
I own Remington RS 8943 shaver. Its battery is worn out. Cant recharge.Please help
This model was not made to have the batteries replaced. It is possible but the shaver body will probably come out very scarred in the process. Instead, the following replacement is suggested
http://shaveroutlet.com/remington-ms32700-lower-unit-p-210.html
May 31, 2010 | Remington MicroScreen 3-3000 Electric...
I've bought 2 Remington shavers, the latest an R836 to replace an earlier model R 875. Apparently if you leave these plugged in at the mains, the battery goes kaput. I haven't been able to find spare...
You will find batteries at shaveroutlet.com. I strongly suggest that you take a look inside your shaver to make sure that you have the skill required to mke this repair
Each of your models uses two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Soldering is required.
Jan 15, 2010 | Remington Health & Beauty
Health & Beauty Logo
200 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
