Question about HP COMPAQ 7540 CRT Monitor
Sometimes my monitor burnt smell and the monitor says "out of frequency range I installed the CD from the monitor.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Your cable is tangled with the power cable. separate it and leave it on for one full day.
Posted on Sep 08, 2010
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
My monitor screen is blank. it also smell as if something is burning.
something is breaking down , some times repairable,sometimes not depends whats burnt out
Jul 05, 2010 | Dell E773C 17" CRT Monitor
My monitor says "out of range" H. frequency: 96.4 Khz V. frequency: 119.6 hz
You have to configure your monitor turn it down the frequency of your monitor range
Jan 07, 2010 | Office Equipment & Supplies
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
How to change frequency range in LCD moniter
Good morning! please try to review/check the operations manual of your LCD monitor, wherein proper set-up settings of Frequency range can be noted. best regards.
May 04, 2009 | X2Gen MG15VT 15" LCD Monitor
''out of frequency range'' on crt monitor
Go into your "Device Manager" in Windows and find out if your HDTV monitor is still installed. Delete the settings under the monitor tab and reboot the computer. With any luck the reboot will cause Windows to re-detect your current monitor and install the proper settings. A similar process may need to be followed with your video card driver as well. CAUTION: Make sure you have a disk or some means of installing a copy of your video card driver before you delete out the currently installed one.
Hope this helps!
OpenSource13
Apr 05, 2009 | Compaq Computers & Internet
Frequency out of range
You need to install the video drivers for your monitor. Go into SAFE mode to install them.
Mar 29, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Ubuntu Monitor
It's a monitor design quirk causing that.
You got the message because Ubuntu read the info your monitor fed back to your videocard and somehow understood it could run the monitor at a higher or lower frequency than the monitor can really work with; say, 120Hz rather than 70 or 55Hz refresh rates.
 If you don't even get the first logo menu, try hitting either down-arrow, then enter, or F4.  Those correspond to menu choices to boot in failsafe graphics mode or get the menu in such a mode.
Sep 10, 2008 | Canonical Ltd. Ubuntu
OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
May 25, 2008 | XFX GeForce FX 5200 Graphic Card
H.V. frequency over range
I have a philips 105s5 crt monitor.First problem is vertical dead.Replaced this ic .Power ok but screen appear" H.V frequency over range" .How to solve this problem.Please suggest me.
Dec 23, 2006 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Computers & Internet Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
