Question about New Home L-373 Mechanical Sewing Machine
I dont have a book and wanted to know how to thread the machine
  • 161 Answers
Http://www.sewingmanuals.com/
try here, even if they don't here your exact model, you should be able to find something similar as the machine all follow the same pattern
Posted on Sep 12, 2010
2 Suggested Answers
  • 1788 Answers
SOURCE: I dont know how to thread the machine or thread a
Download your manual for free at www.singerco.com. Just go under customer support and put in 1866 and voila, you can download it.
Posted on Oct 01, 2010
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
Jul 20, 2016 | Sewing Machines
I dont know how to put the thred in
try visiting www.sewing.about.com for general machine use, threading diagrams and help.
Or borrow a general "how to use a sewing machine" book from your library.
Also buying the Singer manual for your machine is always helpful as it will be specific to your machine.
However, if you've never used a machine at all, best advice is take lessons.
Apr 05, 2011 | Singer 1525 Mechanical Sewing Machine
How do i fill bobbin, thread machine and bobbin?
Did you know all sewing machines are threaded in the same way. The parts just look a little different. If you can thread one machine you can thread them all. Dont you have an instruction book? If not get any instruction book for a simular looking machine. There are many you can dowload for free as a pdf file.
Dec 12, 2010 | Necchi 3610 Sewing Machine
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
Lost manual-don't know how to thread machine
http://www.mastersewusa.com/ or try:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The threading instructions are free if they have your machine...if you want a guide book for using the machine or servicing it, then there is a cost to receiving that information.
Jul 29, 2009 | PfaFF Hobby 4260
Dont know how to use the sewing machine so how do i thread
well!I If you buy a new sewing machine it has a manual to guide you in any brand.But if buy a used one sometime it doesn't have a manual, you didn't mention the type of sewing machine you want to use any how if you have a mechanical sewing machine it's better to start on it.First you must know and must familiarize the significant part of machine and important usage of them,I'll just mention the most usage part at start.Putting thread in bobbins first there is bobbins winder where thread was wind,draw thread from spool through bobbins winder tension disc located at top of machine.wind thread around an empty bobbins serveral times then,place bobins onto bobbins winder shaft with thread wound on bobbins clockwise sometimes this is located at top right side a shaft coupled to circular rubber touching handwheel perpendicular sometime it was located at right side front of machine near handwheel.Release clutch by pulling handwheelor rotating pivot wheel counterclockwise at the center of handwheel whlle holding freeze the handwheel tigh in order to disingage the motion of handwheel from mechanism of machine.
Mar 11, 2009 | Sewing Machines
Simplicity Denim Star SW 210
Thread looping / bunching under fabric sewing.
Incorrect or NO top thread tension, Incorrect threading
Re thread top thread and thread machine with presser foot lifted allows thread to locate into the correct thread tension route.
Thread has not been pulled into thread tension unit- re thread, make sure thread is kept taut while threading.
Jan 03, 2008 | Simplicity American Denim SA1100...
New Home L-373 Mechanical Sewing Machine Logo
69 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
