Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Posted on Apr 19, 2011
  • 3 Answers
Check for corrison on battery terminals.
soleniod may be bad. possibly the starter
chech safety cut off switches.
Posted on Sep 08, 2010
John deere tractor won't start ......turn key and just here one click. the tractor was running fine then it stalled out when i got stuck in mud.
check the solenoid to be sure it is good. possible bad connection at battery or a ground. be sure the battery is good.
May 26, 2017 | John Deere Garden
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Srx75 starter wont disengauge
Replace your starter solenoid. Sound like has fused into the start position,
Nov 10, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 | Garden
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
1,154 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
