Question about Kenmore Kitchen Ranges
Kenmore oven mod 665721323 ser rp5113838 ignitor comes on so does oven igintor goes off so does oven f3 e2 c0de appers
    President:
  • 1,430 Answers
This indicates the oven temp probe is giving to high of a reading. If the oven does not appear to be overheating the temp probe will likely need replacing. It is easy to check and replace. You should have about 1100 ohms. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Posted on Sep 08, 2010
F3 E2 Error Code, but then oven won't turn off
The oven controller may be failed (stuck relay) or the oven temp probe may be failed but this would normally cause both elements to be on at least some of the time.
Nov 17, 2013 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Kenmore gas oven says E2 F3
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 16, 2011 | Ovens
I have an e2 f3 error and the broioler comes on full blast when it's plugged in
Hello & Welcome to FixYa
F3-E2 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
- E0 Oven temperature sensor (RTD) opened
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
I have a Kenmore Self Cleaning Electric Range and I am getting F3 and and E2 Codes. When trying to pre-heat the oven, an F3 code appears and then the oven shuts off. Sometimes while trying to pre-heat...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
I have a Kenmore Super Capacity with UltraBake System. Model number 92004102. I keep getting error message E2 F3 and my oven door locks and my oven turns off. What does this earor message mean?
We have parts for your Kenmore range. You have a series of 3 numbers before the model number that's on your range. Those numbers tell us who manufacured your oven. Once we have this information, we call tell you which part you need to stop the E2 F3 error codes.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday and we can get you cooking again!
We look forward to working with you and getting you up and running again soon.
Thanks, Ella
Dec 11, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Kitchen Ranges Logo
75 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
