Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a 60 inch Phillips model number 60VB2K3RG and it will no longer turn on. I have verified the fuses as well as the power going into the TV all are good. I have even used a DMM to verify power exists on the different boards. Does anyone have any troubleshooting tips to offer?
  • 5 more comments
  • gino_e_casti Sep 09, 2010
    The LED remains off and does not do anything.
    I noticed the model number on this problem shows a 9P6034C but my TV is a 60VB2K3RG and I wanted to make sure that you are aware of the correct model TV.
    Thank you
    Yes I did and all of the electrolytics are in good shape, whene a cap goes it typically will pop the top or have a bulged appearnce to it and this is not the case with all of the caps on all of the boards.
    Do you happen to have a schematic or photos of the internal cabinet pointing out the different boards?
    No chassis number anywhere in the cabinet
  • gino_e_casti Sep 10, 2010
    I checked all of the resistors last night with a DMM and all appear to be good in other words all have a resistance of varying values.
    The chassis number is not available anywhere on the TV.
    Any luck with schematics? Do you have any other suggestions?
    All IC's appear to be good as well, any of your colleages have any tips?
  • gino_e_casti Sep 15, 2010
    It's been a few days now have you had a chence to think about this and see if I can do anything else to troubleshoot this problem?
    If Fixya cannot help do they refund the money I gave?
  • 4,889 Answers
What is the status of the LED at the front? Does it remain off or does it come on and blink? Please provide this info so that we can continue with the diagnosis.
Sai.
Posted on Sep 09, 2010
  • 7 more comments
  • eagle338
    eagle338 Sep 09, 2010
    Something is causing an overload. Did you look for faulty electrolytic caps?
  • eagle338
    I would recommend that you test each and every resistor on the power supply and main audio video board. Should be around 20-30 of them and shouldn't take more than 10-15 mins. We should go by trial and error coz we do not have any blinking codes to help us locate the source of the problem.
  • eagle338
    I will check if I have one in my collection. Can you please get me the chassis number?
  • eagle338
    Sorry I do not have one for this model. No luck finding it anywhere either possibly coz its a rather old model. However if you want me to spot the board or need to know how to read the values on the resistor through color coding then let me know and I will help you .
  • eagle338
    eagle338 Sep 10, 2010
    What about shorted ICs? Did you check if any f them are broke and have formed an open circuit? No luck with the schematics. Tried my sources too. A google search for your model no returns about 4-5 results. So schematic is out of question!
  • eagle338
    There is a particular IC known as Flyback switching regulator. Its in the HV section of the power supply. Did you make sure that you check it? Also may I know the procedure you are using to test the ICs?
  • eagle338
    eagle338 Sep 15, 2010
    Why do people request refunds without trying what has been suggested? You did not answer my last question. Ypu also did not tell me your procedure of testing the ICs!
    I did not see the last comment that is why I requested the refund. As far as how I am checking the IC's I verified the votage is present at each one. I have not looked for an input on each chip as I was hoping that you had a schematic that would allow me to follow a signal through. Do you have a reference designator for the Flyback regulator?
  • eagle338
    You see. You do not need a schematic for this. You can use the Vcc and common ground point on the tv to do this, The only question is which one is the Vcc pin of each IC. If you can get me the IC numbers of all the ICs I will get refer the data sheets and get you the pin no for each of them. Sorry about the schematic. Since the set is very old, its hard to find one. If you want to make your job easier then there is another idea. You can just replace the power supply board to fix this one.
My 60 inch phillips tv, I turned it off the other night and now all i get when i turn it on is the power button flashing green. 6 quick flashes and then 1. I need my tv, plz help
Try a new Web search for your brand. Try looking for a Diagnostic trouble code of 6-1 and see if you can pull up parts of a Service manual using that search routine. Try Phillips trouble codes, Phillips Diagnostic Codes, or your model# in the search.
It sounds like it went into a default Diagnostic mode. If you have a Remote with extra functions it may get you into the Diagnostic menu.
Dec 20, 2011 | Televison & Video
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
Jul 18, 2009 | Philips 60PP9200D Television
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blinking Power Light 9 Times Phillips 60PP920299
go to this link they may have your service manual for your tv they list them by chassis numbers so if you don't see it leave them an e-mail with your model number and they are very good about getting back with you
http://servicemanuals.vstore.ca/
May 09, 2008 | Philips 60PP9202 60" Rear Projection...
Messed up
Probably the convergence board.
First, try resetting the TV by unplugging it for 30 seconds and replugging it.
Does the problem exist on both cable/sat and an external source like a dvd player/vcr?
Go to www.usasupport.philips.com and enter 60pp9200 as your model number - click on the link for the "Quick Start" Guide - read p 8 on manual convergence - if the manual convergence fails, then your convergence board is bad.
Mar 17, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips 60 inch tv
There is nothing you can do to repair the convergence problem it sounds like you have. If it is the older PTV set with crts it will probably cost $200.-$300. for the average repair of this nature.
If it's a DLP model, no convergence in those. Most likely a Light Engine. $500.-$800
Mar 12, 2008 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
