Question about Toshiba Qosmio G15-AV501/R Notebook
I was given a qosmio G15-AV501, but it appears to be overheating about 10 minutes of operation. It will run for a little while, then just shuts down. Between 5 and 15 seconds before it turns itself off I hear an internal fan come on. Then it shuts down. If I try it again a 2nd time it doesn't run as long before the shutdown occurs. After this happens it warm in the center of the bottom of the laptop but does not seem excessively hot. Any suggestions? Apparently this was sent back to the factory once before for overheating problems and I have the receipt for $450 of parts and labor. Not worth that to me, but if there are any simple suggestions I'm interested. Anyone know if this was a common problem? I see no posts about it.
  • will_kranz Sep 12, 2010
    Azraelsrl:
    Thanks, interesting. I'm normally a desktop type, but it was free and seems nice when its running. So worth pursuing.
    I find very little documentation on line on this this, almost as though Toshiba doesn't want lay people to attempt repairs :-(. Do I get to the bios options you mention via setup?
    What is an appropriate temperature range?
    If I hear the fan come on, isn't it working? What I believe I heard is air flow, not just a motor,
    but I will try to open it and look. Have yet to find anything that tells me how to even open the case to see the mother board. Its been trial and error so far.
  • Toshiba Master
  • 11,800 Answers
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Posted on Sep 08, 2010
    Azraelsrl:
    Thanks for the reply an encouragement, but from the sounds it makes the fain does come on,
    what I think I hear is air movement, not just a motor. However Toshiba doesn't seem to show
    much info on who to open it or do repair, ie they seem to want one to pay for it. I have yet to find anything about how to open case, all has been trial and error so far. Any suggestions on disassembly info?
    You also suggest checking the temperature range in bios. I'm not near it now, but do I get to that through the F2 setup option at boot? Doesn't run long enough to do anything else. If so, what temperature range should it be set to?
    Regards, Will
  • Azrael SRL Sep 12, 2010
    To open your laptop use this sitehttp://www.irisvista.com/tech/  the G20 is very close on G15 so the instructions will be pretty much the same.
    To enter in the BIOS you must press Escape while the laptop starts. In there should be something like "PC Health Status" or "PC Monitoring" - in it you will find the temperature settings - make sure they are set at 80 C .
My G15-AV501 Model PQG10U-00Y00L has a growing number of vertical white lines on the LCD screen. The laptop has been used very little and is not used for travel. It just sits on my desk. How do I fix...
hello sir this is Vga card problem.. u need to repair Vga card.. u can repair with rework station .. there is an example .. check this vedio.. in ur laptop VGA chip is biger then this.. Thanks
http://www.youtube.com/watch?v=FA6HcGFqzNE
Oct 15, 2010 | Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio G15-AV501 will not boot
Subscriber/user FMFM85 had posted a solution for another laptop that worked for me. That was Power down, remove battery, remove power, wait five minutes, plug in power and do not install battery, I rebooted to last known good configuration. This method got me further along.from the absolute DEAD state the laptop was in. Now I know that the laptop is really hosed in other ways. I will keep you posted.
Feb 22, 2010 | Toshiba Qosmio G15 Notebook
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Nov 03, 2009 | Toshiba G15-AV501 Qosmio Notebook
Computer has set for along time without being started or charge
get back me @ deepuunni1985@ gmail.com with more details. the issue is not very clear.
Aug 22, 2009 | Toshiba G15-AV501 Qosmio Notebook
New hard drive for my Toshiba Qosmio G15 R laptop
I believe with Toshiba they normally would give you a recovery disk and then a drivers and utilities disk as well. If you don't have both then I would suggest installing windows xp and then go to this page:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835452&rpn=PQG10U&modelFilter=G15-AV501&selCategory=3&selFamily=804517Click on the downloads button and from there choose your operating system and you can download the drivers from that page.You'll know which drivers you'll need by going into the device manager and seeing what has a yellow question mark next to it.If you need more help with this let me know and I'll help you more.
Jun 08, 2009 | Toshiba Qosmio G15-AV501 Notebook
I have a Toshiba Qosmio G15R and I need drivers
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Toshiba Qosmio G15-AV501 red lines in lcd
See the below "copy & paste from another member" I don't know how sucessful these other owners were, but it's worth a try:
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Aug 24, 2008 | Toshiba G15-AV501 Qosmio Notebook
Help with Toshiba G15-AV501 Qosmio bluetooth!!
The solution to your second problem is to insert the CD Qosmio Player Recovery CD. The buttons on the top do actually work (most of the time) yet it seems for some reason qccasionally it takes the CD refresh to get them working again. The picture and sound are great once you have got them working. So, don't be discouraged it's a great PC (once you have resolved your problems) I have had mine for 3 years w/o problems except for this one just described. Good luck.
One other thing I did have trouble with the Bluetooth, I resolved it by buying a Targus Bluetooth dongle, (disaabling all built in Bluetooth) then everything "paired" and worked easily, (unlike the built-in)
Jun 13, 2008 | Toshiba G15-AV501 Qosmio Notebook
Computers & Internet Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
