Question about Philips (MCD700) System
I have 5 Philips MCD700 (Serial # ) speakers which includes a SW-8 subwoofer (Serial # LM010632). I am trying to find a receiver which will power all of them but have not found any luck. I do not want to blow my speakers as I have in the past and do not know what to do. Please let me know which receiver to buy or where I can find one. Thanks. Jarrett
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I cannot turn on my
So are you saying the remote doesn't work or that the unit itself doesn't work? Walk over to it and press the power button.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Jun 29, 2011
Can u hook it directly to a lg tv tried but sounded really bad
What are your front channel speakers connected to? Or are you just using the TV speakers for that? Most TVs don't have a dedicated subwoofer output and that's a necessary level of pre-amp out to give the subwoofer proper low frequency signals. If you have an amp/receiver then it probably has a subwoofer output.
Feb 23, 2016 | Pioneer SW-8MK2 Andrew Jones Designed...
How to hook up psw350 polkaudio powered subwoofer
A powered subwoofer is fed the sw line output provided by the receiver. If lacking, then the woofer might have connections to it from the speaker outputs of your receiver.
Connect them in phase, make sure your sw is in phase with other speakers and balance the sw output.
Sep 20, 2015 | Audio Players & Recorders
I cannot turn on my surround sound on my Philips MCD700 Stereo using the remote, any ideas???????
Jun 28, 2011 | Philips (MCD700) System
Here's my delema...........I have a Pioneer subwoofer HTP102-SW and want to conect to my Pioneer AC receiver. Subwoofer has 8 speaker ports (L+R output & L+R input). Do the speakers connect to the...
The left and right outputs from the receiver go to the left and right inputs on the subwoofer and then you wire the left and right speakers to the left and right outputs on the subwoofer....it is sort of what we calll daisy chained
Dec 30, 2010 | Pioneer Televison & Video
What do i need to install a subwoofer
Here's what you need:
1) An enclosure for the 8" subwoofer.
2) 8" subwoofer.
3) Amplifier to power the sub.
4) Amp wiring kit.
Your Sony has two sets of preamp outputs so make sure that your wiring kit includes a set of RCA's.
Mar 24, 2009 | Sony Car Audio & Video
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Dec 31, 2007 | Kenwood SW-303 Speaker
Philips (MCD700) System Logo
66 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
