Question about Dell Inspiron 9400 Notebook
I have a Dell Inspiron 9400- used. I do not know what has/may have or haven't happened to it unfortunately:( When I turn on the computer with power button, computer clearly turns on, then the DELL startup page is displayed BRIEFLY (like for a split second only!), then the screen goes blank/black and stays that way. What can I do? If anything. Thanks
    Sergeant:
  • 284 Answers
There is some issue with ur display drivers try to uninstall it from safemode and again reinstall it back??
Posted on Sep 08, 2010
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Have a Dell Inspiron 9400, when running off the battery the LCD is perfect, as soon as I plug into power the screen goes black. Ive tried multiple power supplies and still the same result?????
you may need to change your power settings. it sounds like when you plug it in it goes into a mode thinking there is another monitor hold the FN key and press a key usually f5 that looks like a computer monitory. anyway plug in the pwoer cable, and hold fn and press the key that looks like a computer monitor maybe twice until the monitor comes back on let me know if that works!
Mar 17, 2011 | Dell Inspiron 9400 Notebook
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell Vostro screen has started going black every
Check the power settings. Start/Control Panel/Power Options. There is a setting separate from the screen saver to turn off the screen in the Power Options control panel. DVD playback overrides the power options settings.
Mar 25, 2010 | Dell Inspiron 9400 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 Won't Start
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
i suggest that you should replace the battery because batterey may be faulty take it down to your nearest pc repair shop
Jan 21, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
