Question about Dishwashers
It isnt draining water. checked waist pipe and it isnt blocked Looks like the problem is in the machine. regards Brian
  • Dishwashers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 10, 2010
Wixl123 does not drain after washing ?
Drainage problems can be caused by:
a) Blocked Filter chamber
b) Blocked Sump
c) Blocked Drain Pipe
d) Blocked waste pipe
e) Failed Pump
You can check the sump and drain pipe are not blocked by disconnecting the drain pipe from the undersink trap or waste pipe and lowering to a bowl on the floor. The water should drain out into this bowl under gravity if there are no blockages. Bear in mind if you have disconnected the drain pipe from an undersink pipe if youpour the drained water down the sink it will flood into your undersink cupboard. If this drains then you check the waste pipe or undersink trap is clear. You should also check the filter chamber if it is accessible on your washing machine (not all are). I would recommend you unplug the machine or take the fuse out of the switched socket before doing this. Drain the drum as above before doing this or you will get a gush of water coming out. You will usually have to remove a cover from the bottom of your machine to get to the filter chamber and twist it ant-clockwise to unscrew it. Check for any coins buttons etc trapped in there. If there is nothing there check the impeller will turn relatively easily by hand. If you still can't find the problem you might have a faield pump and I would recommend contacting an enginee
Apr 03, 2011 | Indesit W 123 Front Load Washer
My washing machine will not drain at all unabling me to open the machine door as it is full with water, i have tryed putting it on a spin to drain however it the quantity of water in the machine just rose,...
Your pump is probably blocked. Do you have an outside area you can get the machine to? If so, drain it by taking the pipe off as described below:
You will have to tilt the machine to access the bottom of it. The pump will have an incoming water pipe from the drum, and an outgoing pipe to the drain. These pipes are usually fixed with spring clips which you press to release (may need a plier here). Remove the pipe that comes to the pump from the drum.Check for items blocking the pump via the opening for the pipe. You will probably find a sock or some other item blocking the pipe. Remove and re-fit the pipe and spring clip. It should work now.
Sep 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Not draining the water after it's done a wash
hello make sure the drain pipe is not block or kinked if this is ok check pump is not blocked if is ok you may have faulty pump
regards
shaun
Aug 16, 2010 | Washing Machines
Aeg lavamat 64840 keeps draining even when it is empty so no programmes will work We have checked the pump and done all the checks in the manual. It drains water out but then doesn't stop trying to pump...
There are variables but the quickest check with minimum equiptment, i would locate the pressure switch then pull the small clear pipe off that is attatched to it. Firstly , blow into the pipe and see if it isnt possibly blocked.(If it is blocked, the control will see the system as over full and all that will happen is the pump will continue to activate). Before you put the pipe back on the pressure switch, activate the washer for a few seconds and see if the cycle wants to start normally. If so, switch off and reattatch the pipe and do a wash test.
May 23, 2010 | Washing Machines
My machine wont drain or spin. if i maually empty, it will eventually start a wool wash but then says error e20 but filter is clean and no kinks or blockage in drain pipe. should i replace outlet pump?
Do the following.
1. Switch off the machine, unplug or disconnect the mains AC power to the machine and turn off the water supply to the machine.
2. Remove the filter access panel.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 13, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Washing wont empty of water to finnish cycle ive a washer dryer 1100
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
Nov 08, 2009 | Washing Machines
What does error f04 mean on a bosch washing machine
It means that the water is not draining fromthe machine inthe time allowed by the controller.
1. Switch off the machine and disconnect the mains power.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 17, 2009 | Bosch Washing Machines
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
