Question about Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
    Problem Solver:
  • 4 Answers
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Posted on Sep 13, 2010
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
My 650 sub zero vacum condensor error code is flashing and the refrigerators inside temp rose to 58. Should I try and clean the coils first or does this sound like a more serious problem
Good day,
Cleaning the coils on a Sub Zero should be a routine procedure.
At least once a year.
Unfortunately the depth, fin design and overall layout of the Sub Zero machines does not lend itself to vacuuming.
The coils, to be cleaned properly must be blown out, from both ends.
Service techs carry nitrogen tanks or air under pressure with a hose to do the job.
If you do not have access to one of these devices, a quality push/pull shop vac with a crevice tool and some patience will do the job.
It's ugly and messy but there is no other way to do it properly.
It should be done as soon as possible, and if it produces no results on frig temperature a service tech qualified on Sub Zero should be called since it could easily be a serious problem.
Mar 10, 2010 | Sub-Zero 650/SRH Stainless Steel
Vacumm Condenser light flashing
Hello.
Your unit is sensing that the condenser fan is running at a lower rpm than it should. that is how you get the signal. You will need to replace the condensor motor if your coils are cleaned already. That is the only cure for your problem. I hope this helps you out.
Jul 16, 2009 | Sub-Zero 690 Side by Side Refrigerator
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
My vaccume condensor light is flashing and my refrigerator is 55 degrees. I vaccumed the coils on the side of the fan What could be the problem ?
You may need to unplug the fridge for a few hours and let it reset itself. Also make sure coils are clean and there is plenty of air flow to the condensor..
Jul 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero 650 / bottom freezer
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
Aug 09, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
302 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
