Question about Advent 4211c Notebook
SCREEN HAS TURNED ANTI CLOCKWISE - Advent 4211c Notebook
After removing cover and removing cog off shaft on power valve on my kdx 200 which wat do I turn it to fully open the power vale
If you take the exhaust pipe of the barrel you will see two ports either side these will be open if the powervalves are in the open position.but the way you time it properly is to take the barrel off and you pull the actuator shaft out cl
May 04, 2015 | kawasaki KDX 200 Motorcycles
Dropped phone now screen is dark
it had been a pcba hardware issue. the cpu of that pcba is damaged. if u give 214 degree heat and 117 power of air combined for around 2-3 min anti clockwise den it will work again.
Apr 01, 2014 | HTC EVO 4G Sprint - /
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Need switch for stove model 720ef that when turned anti clockwise puts on half off grill and when turned clockwise puts on the whole grill where can i buy one
Sounds like maybe u just need the knob.u can call repair clinic the number is 1866-822-0890 or 1-800-269-2609 they of most parts on hand .I order my parts first day and alwas get them the next day .
Nov 09, 2011 | Ovens
While trying to open my trunk I turned the key anti-clockwise and now I cannot get into the boot of my Toyota cressida granda using the key or the in car lever, help?
My dear unless you replace new key.because the key is to turn once,even if you lock with the key you can get it open with the lever.but now it has interlock it self because of the anti-clockwise turning.thank you
Jun 29, 2011 | Toyota Cressida Cars & Trucks
I've got a Draper 30357 torque wrench. It says in the instructions that the micrometer should only be turned clockwise. But the wrench needs to be de-torqued when not in use which requires turning it...
Had a look at the manual. From what I can see you turn the handle until the zero lines up with the main divisions and then turn the handle for any additional increments to set the final reading.To do this you have to pick the main reading lower than your intended setting and work upwards by adding increments on the handle by turning it clockwise. You could do this by picking the reading above your intended setting and turn the handle anti-clockwise to reduce the reading but you could make a mistake doing the subtraction. I think this is what they are trying to get across. In any case the handle has to be turned anti-clockwise if you are using the wrench to tighten a nut with a lower torque setting.
Mar 30, 2011 | Hand Tools
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
My whirpool oven display reads stop, how do i turn it off?
Hi
This "STOP" message appears when either the cooker has been switched off at the mains or there has been a power cut. What you have to do is a s follows:
1. The knob on the left should be turned anti-clockwise ONE click only.
2. Press the button between the two knobs (under the display) ONCE only. You will now have got rid of the word "STOP" and it will be replaced by _ _ . _ _ symbols.
3. Press the same button twice more or until "12.00" is shown. This is the 24hr clock and can the be adjusted up or down by turning the right hand knob clockwise or anti-clockwise. Its always recomended that you set the clock before useing the oven although you dont have to.
4. Now you can operate the oven as normal.....Good luck with that!
Regards Ian W.
Jul 31, 2008 | Whirlpool AKZ159IX Oven
Advent 4211c Notebook Logo
29 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
