Question about Dell Inspiron 530 Desktop Computer
When I power up my Dell Desktop I get "Microsoft Corporation" on the screen and it goes no further. Once in a while the screen will ask me if I want to check for problems...which I have done. It then says I need to consult someone and turns back off. Is there a way to bypass this to get it open and back up what is on my hard drive?
    Sergeant:
  • 286 Answers
Did you tried to start pc using safe mode??if not try using safe mode and try is it working?? if its working so it means some drivers which has been installed earlier is not functioning in normal mode so try to uninstall and find the exact drivers for it or if still windows not starting means ur windows got crashed.. try to reinstall ur windows..
Posted on Sep 08, 2010
    Novelist:
  • 127 Answers
Hi, this could be the little back-up battery. and it seams if you have lost your setting. if you keep pressing DEL meaning DELETE and this GO'S into the BIOS. you can check what DISK DRIVE IT IS LOADING FROM disk should be disk(0) is the main drive you will know if the settings are wrong the time and date will show 2001 00:4. etc, etc. the on screen changes are done by ESC and moveing UP arrow DOWN arrow. WHEN LEAVING THIS SCREEN PRESS FUCN 10 IT WILL ASK SAVE SETTING Y - N, if the setting are wrong PRESS Y. try not to change some setting as this will make it worst. hope this will help you gerry
Posted on Sep 09, 2010
52H checkpoint error
That's a question you need to ask the Dell Customer Support as it is an internal error code and they will be the only experts able to handle such an issue.
Jul 03, 2012 | Dell Inspiron 531s Desktop Computer
My computer boots up but i never get into the login screen and when i press the keys on the keyboard it beeps
when the screen goes blank or gets stuck on the loading screen. simply press cntrl alt delete -----> task manager ----> file -----> new task ------> then type explorer.exe and hit ok. Once you are in, please download the microsoft hotfix for this issue at http://support.microsoft.com/kb/948790 hope this helps even a bit.
Apr 16, 2011 | Dell Dimension E310 PC Desktop
My pc wont go past the microsoft corporation screen (loading screen)
Open the machine - remove everything but the mouse and key board and one stick of ram- check the connections to the hdd while you're in there.
Reboot the machine - once it hints at getting going after you turn it on - start tapping the delete button -until you get to the BIOS - find the SET TO DEFAULT - there is only one -- it will set you back to default and let you boot up. Once this happens - reboot the machine - if it STILL has trouble - reboot it again and tap F-8 until you get to safe mode - once in safe mode it should give you an error message - copy that down and come back. To get faster answers and better service ask for premium service and ask for me. Thanks e2b512b.jpg
Apr 04, 2010 | Acer Aspire M1641-U1521A PC Desktop
I have a problem with a Dell e173fp monitor. On power up, the power LED goes green and screen flashes on once very dimmly, then goes black.
Look for shorted out transistors (4) (c5706/5707) in the inverter circuits, this is common problem, post back what you see so we can guide you further.
Jan 31, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell GX OS Name Microsoft Windows XP
If the power light is steady amber — The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the microprocessor power cable is securely connected to the system board.
Its a cable that has socket named P2..
Thanks for using fixya
Proton
Nov 09, 2009 | Dell GX260/270 PC Desktop
Black display after vista splash scrren
You may have an infection.
Anyways...this is what you should do to regain control.
When you get to the black screen and the mouse pointer, press Ctrl+Alt+Del
The next screen will ask you what do you want to do...
Select Task Management....(one of the last if not the last option)
You'll get the Task Manager Windows.
Go to the Processes tab
On the File menu choose New Task (Run), and type: explorer.exe
Wait a little bit, and your desktop should come up.
Once there, run an antivirus antyspyware, anti adware etc, to get rid of the problem.
Once you KNOW you're clean and back in track, I recommend you to look into www.labellpcsolutions.com.
They have a product called Pc Guard, that protect your computer from all this problems effectively.
Please don't forget to rate this answer if helps.
Jul 02, 2009 | Compaq Presario 700 470024-192 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Screen is dark
Hi Yacob
First Run a diags on the dell laptop. You can initiate it by pressing fn+power button together and start the laptop. It will go to the diags screen. Tell me if the diags pass or not and then we will troubleshoot further.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 530 Desktop Computer   Logo
104 people viewed this question
Alun Cox
