Question about Whirlpool LSB6200PQ Top Load Washer
How do I take off the cabinet on a LSR8233JQ0 Whirlpool top load
    President:
  • 1,430 Answers
  • Tankr7 May 15, 2011
    Yes Sir , Many Thanks to your efforts, I speak the language you spoke and Man o Man, I made all kinds of good progress. Thank you, Guru of the Appliance world.
    You made me save a great deal of money, This scored all kinds of points with The Mrs too.
    I believe my youngest son at 12 yrs old could follow the great video you made and been able to determine the parts that worked and the ones that were broke. Many Thanks. I Recomend to all.
HOW DO YOU REPLACE A BROKEN LATCH
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=4a891e69ce522c88dc53ea3d0ddbd34e
And see the following Whirlpool parts list and diagrams for top load (commercial ) washers. Consumer models are basically the same:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
And see the Whirlpool / Kenmore Service manual for top load, direct drive machines:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
From these, you should see how the switch attaches to the cabinet and console.
Apr 20, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool top load washer won't wash after filling
The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
This will release the clips that hold the control panel to the top cabinet.
Fold the cabinet to the rear.
Unplug the lid switch in the top of the cabinet on the left side.
Remove the brass clips holding the cabinet to the rear panel.
The cabinet will come off so that you can access the underside for the hinge and lid switch.
Jan 07, 2010 | Whirlpool Washing Machines
Lid activator switch is broken. How do I remove the top of the machine to access this. prying up at the corners doesn't work, I can see little screws in there, but would be difficult to access...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look in the component section for cabinet and/or control panel.
Following is a description of how to remove the cabinet on Kenmore / Whirlpool top load, direct drive washers.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 04, 2009 | Kenmore 22422 Top Load Washer
Need to Know how to remove top and cabinet
first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
May 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Howdo i get the washer cover off a thintwin whirlpool washer tha
the timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Feb 15, 2009 | Whirlpool LSB6200PQ Top Load Washer
Opening top of cabinet
you have to use a putty knife. It is a pain in the neck. there are two clips where the top of the cabinet is there is a slot you can see the clip if you use a flashlight push theputty knife in and pull up. Then do the other side. They are directly in the frontt of the unit
Jan 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Top load whirlpool washer
you don't remove the 2 screws on rear of console lift and roll console back remove 2 brass colored clips on eack corner remove lid switch plug pull cabinet forward and off
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Mar 25, 2008 | Washing Machines
Whirlpool LSB6200PQ Top Load Washer Logo
183 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
