Question about Kenmore Washing Machines
Our 5 year old washer...is giving us a reading of F 11.. which in the manual says its electrical.. we really cant afford to pay sears tocome out look at it and then tell us we need a new electronic board..hmm.. any suggestions? my husband is super handy..HELP
    Brigadier General:
  • 3,006 Answers
Unfortunately, you're taking a gamble either way. You either pay for a trained and correctly equipped repairer who may be able to fix it quickly (or will let you that the machine is beyond economic repair), or your husband buys and installs potentially expensive new parts only to find that they make no difference and he then cannot get a refund.
If your husband has the right tools/experience he can check for obvious electrical faults such as worn motor brushes, loose wiring plugs, dry solder joints, faulty solenoids and failed microswitches without any real expense, but after that you have to decide whether to call the engineer out or to buy another machine. Unlike your hubby, a service engineer will have the opportunity to order in new parts and to then swap them back out if they don't fix the fault, so it can actually be cheaper than DIY: you'll also have a greater chance of getting up and running again and clearing that growing laundry pile.
Modern washing machines are usually designed around a five year lifespan, so even if you do find the fault you can expect that other parts are going to fail soon due to wear and fatigue, but in most cases it will be something relatively cheap like a pump or a switch and some of these can be taken apart by your husband and teased into lasting a bit longer. If the drum bearing eventually fails then it's not realistically fixable these days, but a machine will usually keep going on an increasingly noisy bearing for long enough to allow saving towards a new machine.
Good luck whatever option you choose and I hope that you soon get your machine working again at minimum expense.
Posted on Sep 08, 2010
    President:
  • 1,430 Answers
This is usually the MCU Motor Control Unit has failed. The board is located inside the cabinet of the machine and is easy to replace but fairly expensive. Before replacing remove each lead and carefully check for corossion or loose connections, if none found you will need to replace the motor control board. Here is a link that should help http://appliancehelponline.com/washermotorcontrolboard.html
Where can i get the tech data sheet to get error codes and fix whatever is wrong, cant afford to pay some technician.
http://applianceassistant.com/ServiceManuals/w10329932_l-84_whirlpool_vertical_modular_washer.pdf
Jan 09, 2015 | Whirlpool WTW4950XW Washer
Previous post on a Kenmore washer
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Jan 31, 2009 | Washing Machines
Washer won't run
Well this means your motor is fried.
if it is more than 8 years old it is not worth putting good money into it. time to replace.
Repair or replace?
Dec 05, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Leaking fluid
Hello cousinohlcj,
Welcome to Fixya,
You said, why is my washer leaking a dark fluid?
How old is your washer?
This usually means your Hydraulic fluid is leaking from the washers transmission
When fluid is leaking out of a faulty transmission a it is only a matter of time till it stops working!
Most of the time if the washer is not under warranty it is not worth replacing the transmission which runs about 350 - 400 dollars. That is why I ask the year of the washer!
Huuum, below find my advice
Repair or replace?
Thanks for giving me the opportunity to advise you!
Huuum
Oct 08, 2008 | Kenmore 22422 Top Load Washer
Clunking whirlpool drier
rollers and or felts are cheap,
much cheaper than a new dryer,
and nobody now makes a dryer that will last 25 years.
I have maytags 1972, 1974, kenmore 1968, speed queen 1980,
in each apartment building used by 11 families, to keep them running costs peanuts
new dryers?, - 3 years is all you get before the $$$ starts
Oct 04, 2008 | Whirlpool LER4634J Electric Dryer
Compressor
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old compressor about to go!
At 11 years old My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
The answer depends mostly on the age of your refrigerator,
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
Note that refrigerators under warranty might require service from a factory-authorized technician;
If your refrigerator is out of warranty and is four to seven years old,
given that today's models are quieter and have added features.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
of a refrigerator you replace is likely to end up in a landfill.
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 29, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Washer leaking from bottom
Hello
Welcome to fixya.
You said, your washer started leaking from the bottom after you moved it outside with a dolly you cant tell where it is coming from.
I had a client the other day with the same problem and it ended up that one of the water supply tubes were loose underneath.
And only needed to be tightened. Now you may have A hole or crack in the tube too!
So inspect it when you tighten it. You will need to people to check this!
check if you fell or see water from any other parts when you inspect below!
Be very careful and do not inspect the washer alone.
make sure the washer is turned off and unplugged before you atempt to do anything with your washer.
Let me know what you find!
Repair or replace?
Please remember to leave a rating before you go!
Thank you,
Huuum
Sep 29, 2008 | Kenmore 22422 Top Load Washer
Washer smells like electrical burning
Peace aminajmay,
ngafm At your service!
Sounds like an electrical fault.
If I were there hands on I could be definite.
Only a hands on laundry tech can make the diagnoses.
BUT, how old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Sep 09, 2008 | Washing Machines
Washer vibrates on spin cycle and is falling apart,
Hello
Welcome to fixya.
You say, your door is cracked.soap dispenser is cracked and falling apart?
How old is the washer????????????
Waiting for your response!
Repair or replace?
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Aug 27, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Kenmore Washing Machine. ......Model 25842400
You can go on to sears website to Manage My Home and pull up your manuel for free. Just have your model number.
Apr 30, 2007 | Kenmore 25842 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
