Question about Dell 1710n Laser Printer
The printer will not pick up the paper when asked to print. I can hear a click but that is all that happens.
  • 3 Answers
Either the little rubber tires on the pickup are worn or the gear unit that turns them is not functioning. Remove the paper tray press the white lever on the right in and try to get it to print a test page by pushing the continue button. The arm should come down and the wheels should rotate.
Posted on Sep 10, 2010
  • jonesdb Sep 17, 2010
    I tried this but nothing happened. The arm did not come down. Tried it on another printer and nothing happened on it. Is there something that I'm missing?
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
May 20, 2010 | HP DeskJet 1280 InkJet Printer
Printer not picking up paper from paper tray
1). take all the paper out of the paper tray.
2). look at the printer pickup roller while you enable the printer to print a test page.
3). if the roller is not turning, and hear click sound, then you need to take the printer to be service. The gear that runs the pickup roller is broken.
4). if the pickup roller truns, but you still hear the click sound, then most likely the secondary roller gear is broken. You still need to bring it to be repair.
call the repair shop and find out how much it cost and how long, It is cheaper to get a new printer than to have it fixed.
Jun 03, 2009 | HP Photosmart C6100 All-In-One Printer
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Paper will not feed to be printed
THERE MY BE OLD ON THE PRINTER PICK UP WHEELS CLEAN WITH ALICOLHAL,
TRY SOME DIFFERENT PAPER THE PAPER MAYBE CHEEP PAPER THE MATERAIL OF THE PAPER MY BE MADE DIFFERENTLY AND THE PRINT DOESNT LIKE IT
ROD
Jan 29, 2009 | HP OfficeJet 7310 All-In-One InkJet...
False empty paper tray message
Dude,
If an“Out of Paper” message is shown on your computer and your printer cannot pick up paper, then follow the steps below (in the order) to resolve the problem.
Step 1:Checking the media and print settings:
  1. Remove power cord when the printer is ON, wait a while and then plug it back.
  2. Turn the printer ON.
  3. Place a Paper, which is not ripped, dusty, wrinkled, or bent.
  4. Place the papers of same size.
  5. Tap the stack of the paper.
  6. Verify the stack of paper between 10 to 25 sheets.
  7. Insert the stack of papers into the printer.
  8. Set the paper settings in the print driver.
    • Open a Document in the application, which has to be printed.
    • Click File > Print > Properties > Paper/ Quality tab.
    • In the Size Drop down menu, Select the Size of Paper.
    • In the Type Drop down menu, select Type of Paper.
    • Click OK.
  9. In the Print Dialog box, click OK to print .
  10. Try printing again.
    Note: If this step resolved your problem and you want to print on another media, change the paper in the unit, repeat steps 2 to 7 above for the new media.
this will solve your problem
Dec 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jam / Dell 1710n
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
Sep 12, 2007 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
83 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
