Question about Ovens
Broken handle on Maxim 3 convection oven. Model OV-502. If no official parts dealer, maybe a list of previously authorized repair shops?
  • 833 Answers
SOURCE: Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Posted on Dec 07, 2007
SOURCE: Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Posted on Mar 07, 2010
Testimonial: "I appreciate the response to my problem. Although it is not the fix that is needed I know someone else is dealing with the same problem."
Macmarkus
  • 2605 Answers
SOURCE: I have a Thermador electric
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an overtemp cut-out tripped. Did this problem start following a self clean cycle ?
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Aug 05, 2010
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
tbreeze47
  • 3083 Answers
SOURCE: the oven setting for convection bake stops at 285
I would suspect the thermostat as being bad, but it could be a heat sensor also. Here is a blog that gives general troubleshooting of this problem, and perhaps it will help:
Here's an answer I found on the web from someone that had already changed the temperature sensor:
Gas oven? You need to remove the bottom panel inside the oven and watch the burner cycle. If it's real slow coming back on, this will let temp drop too far inside the oven, which may indicate a bad ignitor. Could be this, or a sensor, or the thermostat. Sometimes upper limit switches go bad. I tried to bring up diagrams of your oven, but could find any one the net. Here's some info on troubleshooting a gas range, and hope it helps: http://home.howstuffworks.com/how-to-repair-an-oven7.htm Good luck.
Posted on Nov 23, 2010
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
How to repair the control panel when the convection oven does not work but other things work
Good Morning Friend,
I understand you want to know how to repair the control panel on your Frigidaire range. I see that the convection oven is not working, however other functions are working. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the convection oven is not working. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
Broken oven switch, Magic Chef gas oven
http://panjiva.com/Manufacturers-Of?q=magic+chef+spare+parts
http://www.partselect.com/Magic-Chef-Parts.htm
It;s a global economy now, and you can order and buy spare parts from anywhere for anything. please use these links provided to source your part,and ship it back to the mother land, Aoteroa.
  1. Find the model number on the appliance to be repaired. Look for a gray or silver label on the appliance that lists the model number and serial number. If you cannot find the tag, check the locater featured on PartSelect.com. Click the link marked "Need help finding the model number on your magic chef appliance?" Then click on the type of appliance. The guide will show possible locations for the identification label, along with a sample label for visual reference. The URL is listed in the resources section below.
  2. Use the part number to make ordering simple. Look closely at the part you intend to replace. A part number will be printed or inscribed on any part that is large enough to display at least six digits.
  3. Order parts from appliance retailers. Call local USA appliance shops and ask if they sell parts. If so, get a price quote for your part and ask if it's in stock, or how soon it could arrive.
  4. Order from online parts dealers. Use your appliance model number and part description or part number to check online parts dealers for prices and ship times. PartSelect.com, RepairClinic.com and AppliancePartsPros.com all sell Magic Chef parts online. The Magic Chef website may also be able to provide needed parts. It also lists owners manuals, warranty information and installation instructions for their appliances (see Resources).
  5. Compare prices and order fulfillment times between local retailers and online dealers. Most online dealers will offer lower prices. A local dealer may have to wait for your part to ship from their supplier. The shipping time between local and online dealers may not vary.
Apr 27, 2010 | Magic Chef 9122 Gas Single Oven
I have a Kenmore convection oven. The oven works on bake, but not on convection. The fan isn't working?? Thanks
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Apr 16, 2006 | Amana AOCS3040 Electric Single Oven
Ovens Logo
156 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
