Question about Whirlpool MH1150XM Convection/Microwave Oven
Microwave oven turned off completely checked outlet ok no lights or power on appliance. Manuel shows nothing about possible fuse to replace or diagram.
  • Whirlpool Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Sep 08, 2010
Won't turn on. Shows no power to it but outlet fine,
Check input power supply by tester if its conform its OK then check the oven control box .try to check any abnormalities there .
Jul 19, 2016 | Bosch 500 HMB5050 Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
All of a sudden the microwave will not coming on at all no clock no nothing, it completely lost power. I've tried a different outlet and it has no power. Did it blow up?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 07, 2011 | Tappan Microwave Ovens
I have power to the unit, I checked the fuse - OK - nothing working on unit
Hope this helps.
Mar 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
GE JVM1190SY/WY My microwave shows no signs of receiving any power. The light won't even come on. I have tried plugging it in to several different outlets, all of which tested good for a 120 volts. ...
Hope this helps.
Jan 10, 2011 | GE JVM1190SY/WY/AY/BY Microwave Oven
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
76 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
