Question about Zenith R57W46 57" Rear Projection Television
I see double images and shadows and the shadows are outlined in red and green. Is this a "do-it-yourself" fix or does it require a skilled technician?
  • 505 Answers
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Sep 09, 2010
The picture has colored shadows and doubled images. People are doubled shadows are red green purple. I would like to know if it worth fixing the tv is about Ten years old. Thank You
In a nutshell, the convergence ICs have failed. The cost to fix by a service company is likely about $300. You may find someone who does it on the side for around $150.
If you are happy with the picture, you like the tv, then $150 might be worth it.
It is possible to do this repair yourself if you have an electronics background.
Feb 18, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Colors gone crazy
convergence chips need to be replaced. if you are handy with a soldering iron, you can fix them yourself with parts from partsstore.com or you can have a technician replace them which is expensive. its cheaper to do yourself
Mar 26, 2009 | Hitachi 61UWX10B 61" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba big screen The tv is like double exposed . I have a toshiba big screen tv and I have double images in red and green. How do I fix this problem?
This is likely your convergence ICs(chips). If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills. you will find the ICs on the largest heatsink in the tv. the part number starts with STK. if you replace them, check the resistors in front of them and replace accordingly. most toshiba will blow up to 3 fuses (f850, f851, f852)
Dec 08, 2008 | Televison & Video
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture red and green not lining up on my Toshiba 61HX70
Repair will require technical and mechanical skills.The red convergence IC will need replacement,which will require the chassis to be removed.After IC change,alignment in the servicer menu may be needed.Go slow--Remember, above all else,do no harm.You have a great tv,so my suggestion is get a senior tech on this one.
Sep 26, 2007 | Toshiba 61HX70 61" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
175 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
