Question about Saeco INCANTO DELUXE Espresso Machine
I am trying find somewhere I can order a replacement tank for the Saeco Incanto Deluxe. There are many sites for other model tanks but I cannot seem to find this one. The magnetic piece that checks the water level won't float anymore, hence it always says Refill Water Tank. I am going to keep searching.
    President:
  • 1,618 Answers
You might be able to just order the float, check this site servicesunlimited.com
Posted on Sep 12, 2010
How it works decalcing, saeco incanto de lux
from the menu select descaling and open the steam knob. The machine is doing descaling.When descaling proces finish fill the water tank with frsh water and rinse from the hot water .When water finish you are ready to drink coffee.
Jul 04, 2014 | Saeco INCANTO DELUXE Espresso Machine
Our Saeco Incanto Deluxe keeps saying "fill water tank" on the lcd screen but the tank is full. I remove the tank and put it back on then it leaks in the area of the hole where the tank sit in. ...
Does not sound like the seal. A bad seal would leak outside the machine.
The cause usually is the magnet in the water tank. Make sure that the magnet is floating when the tank has water in it. Click here to see what it looks like.
Hope this helps.
May 23, 2011 | Saeco Incanto Classic Espresso Machine
My Saeco Incanto Deluxe keeps giving a message "Fill Water tank" even though the water tank is full. Does not allow me to choose any other options. Please Help.
Your machine has a magnet that floats in the water tank. If the magnet is not floating when you have water in the tank then you need to replace the magnet. You can also try to clean the magnet before replacing. It may be dirty and tends to stick to the water tank.
This is what it looks like. http://www.cerinicoffee.com/item.asp?PID=1318
May 15, 2011 | Saeco Vienna De Luxe Espresso Machine
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
Water is full, but red water light is on and coffee wont come out
Try lifting the water tank and make sure it is pressed along the back of the machine when you put it back in.
Sep 28, 2009 | Saeco Incanto Classic Espresso Machine
Descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Algae in water tank?
Try to clean it with soap, if you are careful you can bend in the edge and take it off.
Use some glue on it when you put it back.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
Saeco INCANTO DELUXE Espresso Machine Logo
80 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
