Question about KitchenAid KEHS01P Electric Dryer
Dryer just stop giving off heat. Gas valves are open. Any ideaa
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
DRYER HEAT TURNS OFF AFTER ABOUT 30 MINUTES
  • Get on with replacing the gas valve coils shown to you in the previous link, it will take care of your problem.
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jun 07, 2008 | Whirlpool LGB6300 Gas Dryer
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
Stopped heating. Had service repair yesterday and he replaced the ignitor. Does not heat again, even though it warmed up briefly after the repairman completed the job. What else could the problem be?
Hello- Have him come back out (AT NO CHARGE) and check the gas valve coils these are probably not opening the valve, thus letting the gas out. It is a common issue and sometimes we, the Techs, need to sit there and watch the ignitor light the gas for a whole cycle. Often it will heat for 30 minutes and then the coils will stop opening the valve when told to by the timer. It is possible that there is a thermostat issue but less likely. Hope this helps, best regards.
Sep 27, 2010 | Amana ALG331RAW Gas Dryer
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
My dryer will not get hot
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
KitchenAid KEHS01P Electric Dryer Logo
43 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
