Question about Refrigerators
I have a chefmate small freestanding refrigerator and it does not cool and the fan dose not seem to work. What can I check for or how can i trouble shoot?
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
"I have a kenmore coldspot model 106.54382300. The freezer is working fine, but the refrigerator doesn't seem to be cooling. We just bought this used and it has worked fine until tonight, when we finally...
Can you hear a small fan blowing air inside the refrigerator? It sounds like the evaporator fan has gone out and it is not transferring the air from the freezer to the refrigerator in order to cool!
Oct 09, 2014 | Refrigerators
My chefmate refrigerator is 1yrs old and started making a loud humming noise. What is it and what do I do 2 fix it? Everything inside is still very cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Compressor seems really hot. Had clicking sounds in my unit, but it was still cooling. Last week it stopped. I replaced the motherboard and it worked great for 2 days. Now it stopped cooling well. ...
It sounds like you have a small leak in the refrigeration system and that your unit is low on freon...
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 12, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
(1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Jan 12, 2009 | U-Line 15R Compact Refrigerator
Settings for a chefmate refrigerator.
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Nov 27, 2008 | Kitchen Appliances - Others
Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Jan 03, 2008 | Refrigerators
Refrigerators Logo
604 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
