Question about Breezaire WKL 4000 Wine Cooler
Not cooling... cleaned the rear grill, temp at 80 degrees. when press the thermostat button to lower the temp, nothing happens
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
IF BUTTONS DONT RESPOND THEN YOU HAVE TO REPLACE THE CONTROL BOARD SENTRY III
CONTACT THE MANUFACTURER TO OBTAIN REPLACEMENT BOARD 858-566-7473
Posted on Sep 16, 2011
How do I turn heater off. Its 80 degrees out. And will I be able to turn back on when needed?
lower thermostat set point. and you can put it any temp you wish. heater below set point runs heater ave set point is off
May 04, 2018 | Heating & Cooling
Water pressure good, thermostat calling for heat boiler ignites , heats to 80, turns off, drops to 40 reignites - keeps this cycle going. temp sensor? return sensor? any help appreciated
the thermostat has an upper and lower setting at which point to turn the unit off and back on
most have a 10 degree variation between off and on so that a steady temp is maintained
check to see if the lower setting can be raised closer to the 80 degrees
if not consider a new thermostat with closer settings
Feb 13, 2016 | Water Water Heaters
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
Same problem...then discovered my thermostat was set to Celsius instead of Ferinheight... pressed toe temp up and temp down buttons to change..fixed...
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
Air lock cooling system
Not sure I follow your wording on the different temps. If the system is full of coolant and working correctly, the thermostat should open at 195 degrees which would be several miles down the road. Once the thermostat opens both radiator hoses should be warm. If the water pump is not working the engine will get hot very quickly.
Have you tried running without the thermostat to see what happens ?
Mar 05, 2014 | Hyundai Elantra Cars & Trucks
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have a honeywell thermostat model#th6110d1005 and it wont go below 68 degrees how can i removed the lock
i just called customer service for the same problem. Push the fan button, which is the MIDDLE BUTTON of the 3 bottom buttons, and the UP ARROW button at the same time, you will see the number 1 on the left of the screen. Press the bottom right button until you see the number 28 on the left, 68 should be on the right. Press the DOWN ARROW until you get to the desired temp, it won't go lower than 50. Then press ok.
Jul 12, 2010 | Honeywell Electronic Programmable...
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Have arrived at my 81 year old mother's house in 106 degrees AND I CANNOT GET THE DIGITAL THERMOSTAT to TURN ON THE AIR and FAN. HELP!
slide switch to cool and press doen button to lower the temp to desired temp. Check thermostat to see if it needs batteries by snapping front cover off. Good Luck
May 18, 2009 | Honeywell Electronic Programmable...
Furnace shutting on and off every four to five minutes all day
Have you had furnace cleaned? Have you changed filter or took filter out and try heater? Have you checked return grill to make sure you don't have anything in front of it. Return grill or duct could be blocked or two small. Blower motor could be going off on thermal overload. Does the heater do the same thing when it is 20 degrees outside. The other thing it could be is furnace is not big enough.
Good luck let me know what you find out
Jan 17, 2009 | Honeywell Electronic Programmable...
Breezaire WKL 4000 Wine Cooler Logo
143 people viewed this question
Top Breezaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
