Question about Kenmore 54383 Side by Side Refrigerator
I woke up last night with water running from under my refrigerator flooding my kitchen & basement. What could be causing the problem? Also how do I remove the evaporator pan? So much stuff is blocking its removal.
  • 1,531 Answers
Check and make sure that the water fill valve does not have a crak in it usually not enough water in the defrost pan to cause any kind of flooding issue. it is either a bad water valve or a broken water line somewhere on the unit
Posted on Sep 08, 2010
Kiddle smoke and carbon monoxide alarm that talks 3 of them one ine bed room one in kitchen. Last in basement wired.
All smoke detectors have a 9v battery in them. Try swapping the battery to see if it clears the beeping.
Feb 01, 2018 | Refrigerators
My defy front loader filled up with water at 2am last night while not in use...flooding my kitchen. the machine tap is always left open, but is active only when the machine has been switched on???
the water inlet valve is faulty and is not closing fully when powered off causing a small but constant stream of water coming into the machine until it floods out the front, you will need to replace the water inlet valve, in the meantime turn the taps off when your not using it
Feb 10, 2017 | Washing Machines
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Ice maker water inlet keeps running
Replace the water inlet valve. It's on the back where the water supply hooks.You can turn the water off usually under the sink.
Dec 10, 2009 | Roper Refrigerators
Refrigerator was in the basement with 6" of water....
The electric parts that got wet will need to be dried out. Try putting a flood light etc. shining on the bottom for a few days to see if it will dry it out, then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
My icemaker shoots water every where. What can i do?
If the water was still running then the water inlet valve where you disconnected the water is stuck.It can get sediment in it causing it to stick open. Clean it or replace it.
Sep 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
The water feed to the ice maker will not shut off.
Either the water valve has stuck open or the IM water switch is stuck. Unplug the wires from the water valve and see if the water has stopped. If yes it is the switch, if still running in the it is the valve.
Eric
Jun 20, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Kenmore 54383 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
