Please need help setting up Sharper Image ko 500 wireless bluetooth speakers cant seem to get sound out of them .Need Step by step instructions. i have cd with drivers and all necessary parts except manual. Please help
Open SKy
  • 620 Answers
SOURCE: installation of Logitech v10 speakers
Happy Holidays Joedge
Well, if you connect all wires on the right place, you should be fine, and welding them according to the place or schematics. but, beware , may be you got a bad sound card inside.
Carl
Posted on Dec 19, 2007
pishta68
  • 579 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
..check it out....
http://www.blurtit.com/q717681.html
Posted on Feb 17, 2008
pagebor
  • 2785 Answers
SOURCE: No sound
just reinstall the sound drivers from the manufacture web-site and reinstall it
Posted on May 08, 2008
ginko
  • 19396 Answers
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Posted on Jul 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: I have a set of
They went bankrupt because their so called air cleaner weren't cleaning anything in fact there were studies conducted that it was doing the end user more harm then good.
Has Sharper Image took the time to read the EPA research on ionizers in the first place, they could have save themselves a great deal of trouble.
It looks like your out of luck getting it fixed but finding a replacement shouldn't be a problem.
I believe Bose makes a similar product.
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
To pair your device with The Sharper Image Freedom:
  1. Make sure your device has Bluetooth capability.
  2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
  3. Follow the instructions of your device to pair the unit.
  4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
  5. Press play on your device and use controls on the unit to adjust desired volume.
Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
Nov 19, 2013 | Radio Communications
Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
Cant get my wireless router to go wireless followed cd manual when i take the lead out to go wireless i get no conection iwent step by step twice and nothing???help please thanks wie=reless g router model...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Aug 14, 2010 | Belkin (F5D7633UK4A) Wireless Router
I need to get sound incoming with headset how do i do this?
Specifying if this was Windows XP or Windows Vista would make a difference in the fixing of this problem, I am going to explain for Windows Vista hoping that you are up-to-date on the most recent operating system.
Step 1: Locate your task pane in the bottom right corner of the screen.
Step 2: Playback options (I believe)
Step 3: Under "Playback" select your headphones from the list.
Step 4: Right click it and click "Set as default device"
Wallah, it should send the sound to your headphones now rather than the PC's output device, please note, once your not using the headphones anymore you must set the default device back to the normal speakers or you will have no spound.
Apr 27, 2009 | Insignia Bluetooth Wireless...
I need instruction to the the sharper image jumbo universal remot
send me your email address and I will send it to you.
585@snet.net
AL
Mar 17, 2009 | Sharper Image Sound Soother Fifty with...
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Jul 19, 2008 | Audio Players & Recorders
238 people viewed this question
 Grubhead
Grubhead
