Question about E-Machines M5405 Notebook
M5405 emachines A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time restart etc. error Stop: 0x0000007B (0xF7900640, 0xc0000034, 0x00000000, 0x00000000)
Geekinator
  • 183 Answers
SOURCE: Can't restore my computer
Here's your GEEK-steer …
Is the DVD you mention the manufacturer/reseller's recovery disk? You'll readily know because its user interface screens will display NON-microsoft business name such as eMachine's, etc. Or is it an actual Microsoft Windows Operating System (XP, Vista, etc.) installation disk?
If it is not the Microsoft Windows disk AND you have no other means of recovery/restore [such as a drive image backup (Norton Ghost, etc), registry recovery (i.e., ERUNT), etc.], then you'll need to perform an in-place Windows "Repair install" (if XP)/"System Restore" (if Vista). However, you can only do this if you have a Windows installation disk. Did one come with this particular eMachine computer?
If you did NOT receive one from the vendor who sold you your M5405, you NEED TO CONTACT THEM AND INSIST UPON ONE. This is an ALL-TOO-COMMON situation that all system buyers need to put a stop to by not accepting anything less than their own disk [for the very reason you need it now!].
If you get nowhere with that (or you can't wait for it), you CAN use any other Windows disk you can get your hands on from someone you know with the same version you're running (XP, Vista, etc.). However, YOU WILL NEED YOUR WINDOWS AUTHENTIFICATION CODE to complete the repair. You can NOT use the user's code from whom you borrow the disk.
Assuming you have (or will soon have) a Windows installation disk:
Insert in into your CD/DVD drive, then boot your system. Then, for step-by-step instructions, refer to the following as applicable:
XP:
http://www.michaelstevenstech.com/XPrepairinstall.htm
There's a lot of very busy clutter and info there, but the operative section begins at "XP Repair install".
VISTA:
http://www.windowsvista.windowsreinstall.com/#Windows_Vista_Home_Premium__Uninstalls,_Upgrades,_Installs,_Diagnostics,_Reinstalls_and_Repair_Guides.
  1. Click on the applicable version at the heading of the page
  2. Click on the "single page" link next to "How to use the Windows Vista Home Basic CD or DVD to repair a Startup Problem"
  3. Follow the step-by-step instructions.
NOTE: This procedure will only modify/refresh your Windows operating system files, not your installed applications or data.
IMPORTANT: After completion, you will need to bring your system up to date with all critical security patches/hotfixes released since the date of the disk you used in this procedure. Do this immediately after you successfully boot into Windows, but make sure you have a firewall running before you go online to perform these updates.
TIP: After you wake up from this bad dream and all is once again serene in your computing world, take some necessary steps, so you never have to rely on this very primitive recovery method again.
1. Get "Emergency Recovery Utility NT" (ERUNT) to accommodate recovery from any future Windows Registry caused boot-failures. It is ESSENTIAL and FREEWARE, so there's no excuse not to add it to your recovery arsenal.
Referrer: http://www.larshederer.homepage.t-online.de/erunt/
Download: http://dundats.mvps.org/Files/erunt-setup.exe
2. Employ a (system) drive and data backup system via a third-party software. There's an endless array of choices, but I cannot recommend highly enough that it be "image" based. "Norton Ghost" and "Acronis True Image" are two of the biggest boys on that block, and either are solid choices. They may cost you a few dollars, but nothing compared to the loss related to computing downtime, time and aggravation of recovery, and most importantly your precious, irreplaceable data. A word to the wise is sufficient.
Good luck, and please post back with a status report and/or any further questions you might have. Especially if you do download and install ERUNT … I can give you a couple GEEK tips to optimize it.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 15, 2008
cabanagj43
  • 225 Answers
SOURCE: Dell Inspiron E1505
Run a diagnostics.
Make sure laptop is off.
Press and hold Fn key and press power button at the same time.
The PSA test will start and it will give you display test first then after the memory and hdd test. complete the test and wait until it gives errors like 0141 / 0142 / 0146.
If you get one of these errors try reseating the hdd. Then run again the test. If still fails then replace the hdd.
Posted on Oct 24, 2009
SOURCE: 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000
This also works for Gateway PCs. The only difference is that you change the RAID setting from RAID to IDE
Posted on Jan 11, 2010
dreamkam
  • 83 Answers
SOURCE: When i am installing windows xp on Hp pavlion dv3
Since, for your laptop you are downgrading the operating system from Vista to XP then with HP notebook.
You need to disable Native SATA support in BIOS utility and go ahead with the installation. To disable the SATA support you need to follow the below steps:
== Disable SATA native support:
1. Turn on or restart the notebook.
2. Press the F10 key when the "HP Invent / Compaq" logo appears on the screen. This will open the BIOS menu.
3. Select the "System Configuration" tab.
4. Select "Disabled" for the "SATA Native Support" item.
5. Press F10 to Save and Exit. Choose Yes for "Save configuration changes and exit now".
For more information on this visit the below link from HP.
Problems with SATA Drivers When Downgrading From Vista to XP
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01675438&cc=us&lc=en&dlc=en
if you get any problem while doing this then plz get back. Actually you need to do lot of things to downgrade from Vista to XP on HP preloaded vista operating system.
Let me know if you find any difficulties doing this..
I hope this will help you to get it work. Plz vote for me..Dreamkam
Posted on May 24, 2010
  • 1705 Answers
SOURCE: laptop issue
You've not posed a question, this looks like a cut and paste of the typical report from a blue screen crash.
Just follow the instructions :-
1) IF THIS IS THE FIRST TIME YOU'VE SEEN THIS ERROR SCREEN RESTART YOUR COMPUTER.
2) IF THIS SCREEN APPEARS AGAIN FOLLOW THESE STEPS: CHECK FOR VIRUSES ON YOUR COMPUTER.
3) REMOVE ANY NEWLY INSTALLED HARD DRIVES OR HARD DRIVE CONTROLLERS.
4) CHECK YOUR HARD DRIVE TO MAKES SURE IT IS PROPERLY CONFIGURED AND TERMINATED.
5) RUN CHKDISK /F TO CHECK FOR HARDDRIVE CORRUPTION, AND THEN RESTART YOUR COMPUTER.
Posted on Jul 19, 2010
APROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SHUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER
While you may not be using a Windows 2000 computer, the error/cause is probably similar: http://support.microsoft.com/kb/256841
Try to manually install the Standard PC hardware abstraction layer (HAL):
  1. Reboot the computer to restart Setup.
  2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
Nov 10, 2011 | E-Machines eMachines Desktop PC
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
this error comes from hardware .restart the system and press F8 key in start then choose safemode option and log on the system.then remove the software which you install on the system before error.try it it solve this problem......rate it
Apr 16, 2009 | Computers & Internet
Try to do a system restore and see if it works fine..
Try to log on to safe mode using F8 and then choose system restore.
Apr 15, 2009 | Computers & Internet
Turn computer on, screen stays blank.
Hi there Eliot.
It does sound like a graphics issue, go here and select "downloads" for all the drivers for that computer .
http://www.emachines.com/support/product_support.html?cat=Notebooks&subcat=M%20Series&model=M5405
Post back if you have more problems and good luck!!
Feb 14, 2009 | E-Machines M5405 Notebook
On start up goes in a continuous restart cycle
There is usually a hot key you can press during boot up to start recovery (F11 is typical) This will guide you through the recovery process. I would first check all of your cables going to your hard drive, and also the one going from the hard drive to the motherboard. See if that helps. Best of luck to you!
Dec 08, 2008 | Computers & Internet
No boot up
Solution :
  • Run chkdsk /r or chkdsk /f to detect and resolve any file system structural damage.
  • After you use the Chkdsk tool to repair the corrupted NTFS volume, rename %SystemRoot%\System32\Drivers\Ntfs.old to Ntfs.sys, and then shut down and restart the computer.
  • Try disabling any virus scanning programs, backup programs, or disk defragmenter tools that constantly monitor your computer.
  • Run any system diagnostics that are supplied by your computer manufacturer, especially a HDD check.
Jun 06, 2008 | Computers & Internet
E-Machines M5405 Notebook Logo
121 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
