Question about GE Microwave Ovens
GE Microwave Model JES1651SJ-02, Serial 902410. Unit appeared to be fine yesterday evening with the clock working properly but this morning it shows no lights and keypad is not operational. Checked both receptacles with a lamp and they are both provideing power. Plugged microwave into another receptacle on a different circuit and unit shows no sign of having power. Is there an internal reset that needs to be reset or fuse that needs to be rreplaced.
  • GE Master
  • 9,047 Answers
There will be a fuse, magnetron thermostat / thermal cutout, and an oven cavity thermostat / thermal cutout.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Sep 08, 2010
Testimonial: "Confirmation that there is a fuse(s) is very helpful, and that there is a schematic is even more so. Thank you very much for the information."
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Wont turn off
This is either a sticking relay, in which case you'd need circuit board repair, or a sticking door switch or defective door switch mount.
See my help file on door switches here.
If you need further help, feel free to contact me or follow up here with your full model number.
May 31, 2012 | GE JES1651SJ Microwave Oven
My General Electric Household Microwave JES1651SJ just quit working. could it be the internal fuse?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 24, 2010 | GE JES1142SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Dec 16, 2008 | GE JE1860 Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
420 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
