Question about Northstar Pressure Washer Trigger Spray Gun 4000 PSI, 8 GPM
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
    President:
  • Northstar Master
  • 1,388 Answers
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Posted on Sep 08, 2010
My northstar pressure washer has no pressure
PDF]Owner's Manual - Northern Tool + Equipment
https://www.northerntool.com/.../1577544.p...
Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
Sep 21, 2015 | Northstar Garden
How do I fix a bad gas problem
If the gas is bad, The gas bowl needs to be removed and drained, it holds gas ready for the carb. disconnect the gas tube going into the bottom or bottom side of the gas tank. once it is drained, replace bowl, connect hose and re-fill. It may take a few tries, priming it first will reduce the pulling time. It shoots new gas straight to the carb.
May 09, 2010 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer with a comet pump AXD 3020G that will not build up pressure, can you give me some ideas on what may be wrong ,I have checked the screen on the inlet ,it is clean
Normally, it is one of three things.
1.) The high pressure seals are bad
2.) There is debris in the check valves
3.) the unloader is stuck in by-pass.
Nov 16, 2009 | Northstar Pressure Washer 3000 PSI
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Sep 03, 2009 | Northstar Pressure Washer 3000 PSI
Northstar Pressure Washer Trigger Spray Gun 4000 PSI, 8 GPM Logo
424 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
