Question about Acer Aspire 5100 Notebook
My usb drive is showing write protect. it is not format. pls help.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Plug it in pc, go to start, explore, select the removable drive, right click and format it, dont select quick format, it will solve your problem.
it is due to virus.,
cheers!
Posted on Sep 08, 2010
Testimonial: "it did it. cool. "
4gb microsmart usb not formatting
TRY TO FORMAT WITH COMMAND
1. CONNECT UR USB
2. START > RUN > TYPE " CMD "
3. WHEN THE WINDOW OPEN. TYPE
4.
G:
FORMAT G:
5.THEN PRESS " ENTER "
6.PRESS " y "
Apr 11, 2013 | Electronics - Others
Hello sir i am having 8 GB transcend pen drive some of them did password fom my pen drive i tried to format so many times but it showed as the device is write protected after some time i tried...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Computers & Internet
My USB Flash is showing write protected, can't even format it
try using this software to format...worked great for me...
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Sep 21, 2009 | iLO (2 GB) MP3 Player
My usb drive is write protected i cant format it pls help....
Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
Jun 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Hi ,i having 1GB of flash drive of Transcend company.for some unknown reason that showing "write protected ,disable it to use" message is coming.i tried several ways but not succeeded.how to disable that...
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Jun 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Usb is
Try this,
Format your Flash Drive after backing up your data using this tool,
This will format the drive in RAW file system. After doing format using this tool, perform a general format in windows by going to disc management. In disc management, select FAT or FAT32 as file system based on the capacity of your flash drive. IF it is upto 2 GB format using FAT and if more than that format using FAT32.
Please let me know if you need further help.
Thanks
Dec 15, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
