Question about Singer Inspiration 4220 Mechanical Sewing Machine
What bobbin should be used for a singer inspiration moder 4220
  • calllab
    calllab Jan 11, 2013
    I already read the whole manual and for the bobbin, on the manual just appear a lon number, nothing same as 15 pr 15j
    Genius:
  • 1,788 Answers
Normally it is a #15 or 15J. Your manual should tell you or you can go online at singerco.com and look under support for a free download of you manual. I checked the Singer site and you may have to have a "surefit" bobbin that is exclusive to Singer. You can call them at 1-800-4singer
Posted on Sep 12, 2010
I needed to replace th bobbin case because was broken. Unfortunately, by mistake, I removed the positioning plate. Now, I just cannot put back the parts ( bobbin plate and positioning plate). Is there
The parts list (or chart) may be useful to you, and generally, they are free. The Singer Sewing Machine site does have parts charts for sewing machines as a free download. Go to the Singer Sewing Machine site and type in Parts Chart in the Search box. If you don't find it there, send an email to Singer Customer Support. The reason it might be useful is in addition to a list of parts and their order numers, there are diagrams as to what they are and how they fit together.
Jun 30, 2014 | Singer Inspiration 4220 Mechanical Sewing...
How can I replace bobbin case on Singer Inspiration 4220
Download the instruction manual free from the Singer Sewing Machine site, and go to page 62. It will show you how to reinsert your bobbin case.
The flat part goes UNDER the needle; there is a projection on the right side of the case towards the bottom that must rest against a silver part that is actually a cushion spring and prevents it from spinning. It's pictured in the manual.
It's helpful when reinserting it to insert it slightly clockwise of where it should go--that is, placing the flat part slightly to the right, then twisting it counterclockwise into the correct position, with the case's projecting resting against the spring.
Jun 21, 2014 | Singer 7442 Mechanical Sewing Machine
THREADING AND BOBBIN LOADING HOW?
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf or http://www.youtube.com/user/SingerSewingCompany or http://www.singerco.com/sewing-resources/operation-basics
Feb 16, 2014 | Singer Inspiration 4220 Mechanical Sewing...
Bottom thread: you can pull right out of material after stitched.
Very vague question... well it's not even a question. If the bobbin thread is straight with little loops... your top tension is too loose. Tighten it.
Sep 24, 2013 | Singer Inspiration 4220 Mechanical Sewing...
Bottom thread pull out after stitched What is my mom doing wrong
try a new needle
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
try adjusting the top thread tension
if these suggestions don't help then it would be a good idea to have the machine checked
Singer 4220
try changing the needle
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
May 02, 2012 | Singer Inspiration 4220 Mechanical Sewing...
WHEN TRYING TO PICK UP THE LOWER BOBBIN THREAD - HAVE NOW BROKEN TWO NEEDLES. THEY BEND AND SNAP AS IF THE MACHINE IS OUT OF SINK WITH ITSELF.MY MACHINE IS A SINGER INSPIRATION 4220 . (I DONT REALLY KNOW...
Make sure the needles are installed with the flat side facing the back of the machine.
Open the bobbin area and hand walk the needle down to see what it is hitting.
Check the bobbin case and shuttle to be sure they are in place.
Needles can also bend and break if they are too small for the thickness of the fabric.
Feb 28, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Singer 4220 bobbin thread wont raise
To learn how to solve the bobbin problems and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 23, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Singer Inspiration 4220 Mechanical Sewing Machine Logo
93 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
