Question about HP Pavilion dv6000z Notebook
Battery of my laptop is not charging .It is constantly showing 37% charged. charging is not increasing nor thegreen light is glowing but laptop is running with A.C. power. AC power light is glowing constantly. Battery light glows once when i connect the laptop with power after each close. there after disappers.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
Batteries keep going flat
No it does not, there is no connection.
If the alternator was not charging, your charge light should glow to tell you that. If the charge light is NOT glowing while driving, then you simply have a dying battery which cannot hold a charge for long.
The oil light not glowing when the ignition is turned on shows only that the globe has failed.
Jan 25, 2014 | 1997 Mitsubishi Montero
No light indicator charging battery adapter
If the computer starts with the power charger plugged in, then replace the battery.
good luck
Sep 20, 2013 | Dell Vostro 1014 Notebook
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
It is plugged in but not charging,eg if 40% is the battery charged is available then it does not increases the battery life. neither the charging light is lighting.
HI, sounds as if you may have a bad battery. Go into you control panel and check you power options, it will show you how much of a charge you battery has left, and also if the battery is charging.
Dec 20, 2010 | Acer Computers & Internet
Glow bouy will ony stay on for 45 minutes
According to the owners manual for these swimming pool lights, if you light is not working for the full amount of time expected (at least 4 hours) you should try the following troubleshooting steps:
1. The battery pack might not be fully charged. Check the charge and recharge if necessary.
2. The battery pack or charge might be defective. Run the light through several charging cycles. If it fails to hold a charge but the indicator lights are showing normal operation, take the light to an authorized repair shop.
3. The battery pack might be old. After approx. 600 charges, the batteries might lose their ability to be charged. If this is the case, take the light to an autorized repair shop to receive new battery installation.
4. The product might be overheated. The light's internal temperature regluator will shut of the product to prevent damage. Allow the light to cool down and then test for normal opperation.
Jun 15, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
How long do I need to charge my new Nikon D300 battery?
The EN-EL3e battery requires about ninety minutes for a full charge.
The charger will show a blinking light while it is charging. Once it is charged, the light will glow steady. Wait until the battery is cool to the touch before removing it and unplugging the charger.
Aug 30, 2008 | Nikon Cameras
Laptop plugged in not charging
Is your battery charging light glowing on your lap.If yes then have u charged it for a quite long time.If yes then u may need to change your laptop battery.finf the tech. information on the battery,your model no etc. to get one new battery.
Jul 21, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
