Question about Starrett T216XRL-1 - MICROMETER, DIGITAL
My 721 Starrett is only showing the bottom half of the display.
3 Suggested Answers
SOURCE: I just aquired a Starrett 721 digital caliper that
More than likely. But to make sure: check that new battery is good (voltmeter). Check with ohmmeter across the battery contacts - should read few hundred ohms to few kiloohms. If OK, reinseret battery. Push ON button. Push reset button. If go, congrats. If not, get another caliper.
Posted on Dec 07, 2009
  • 25 Answers
SOURCE: Starrett 721 6 inch Caliper
you might have some crud between the coded strip and the reader behind the display, or a chip trapped some where. try cleaning all the parts you can get to it with an alcohol prep pad. As a last resort Starrett will refurbish it for you. it isn't that cheap but it will be less than a new one. give them a call.
Posted on Feb 28, 2010
How do i shut off my starrett electronic slid caliper?
Hello there
From the manual here
http://www.starrett.com/docs/other-downloadable-resources/798-electronic-slide-caliper-user-manual---form-951.pdf?sfvrsn=3
Automatic shut off of display after 30 minutes of non-use
Reactivation of display with movement of slide with no
loss of position
Sep 24, 2014 | Cars & Trucks
Starrett repair
I these punches are adjustable. Does the top turn or the bottom part turn. I use WD 40 or the likes to loosen mine up.
Jun 07, 2014 | Starrett 18a Automatic Center Punch
Need Starrett 682EMZ Saw Tension user guide
I can't find any available manual. I have an Starrett tension guide before but It was an old model and I don't even have manual for it. Did you try calling Starrett? They might can send you one.
Aug 13, 2013 | Starrett 682EMZ 60000psi or 4000kg per Sq....
How do I calibrate a Starrett model 449 depth micrometer?
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
http://www.mytoolstore.com/starrett/micro029.html
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
Jan 31, 2010 | Measuring Tools & Sensors
I just aquired a Starrett 721 digital caliper that wouldn't turn on. Took cover off and batteries were in reversed polarity. New batteries didn't help. Is the display fried?
Dec 07, 2009 | Starrett Electronic Caliper
Monitor is showing bottob half display and upper half is blackout
Hate to say it, but time for a new monitor... will cost you WAY more to fix than to pop-by a garage sale and grab a new monitor.
(It's not even worth a repair-persons time to do it...)
Aug 31, 2009 | Philips 105S51 15" CRT Monitor
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Starrett T216XRL-1 - MICROMETER, DIGITAL Logo
83 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
ray gallant
Mark Schmit
Mark Schmit
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
