Question about InFocus LP 850 Multimedia Projector
LP 850 won't turn on - InFocus LP 850 Multimedia Projector
Have you got the top on, there is a safety switch on next to the bulb. if you are working from the rear its on the left side of the bulb, this has to be pushed down to contact the sensor.
Posted on Feb 05, 2011
Diesel injector pump CAV 55/850/9/2160 or maybe LP 55/850/9/2160. From a 3165 MF tractor. Is it compatible with 3240F938 or Lucas 40B 883517M91
it is possible that it will fit but the major problem is not if it fits-- but is it calibrated ( fuel settings)correctly for the engine
this should only be discussed with a specialist diesel pump repair shop
if it fits but is not calibrated properly , they can reset it for the engine
with diesel engines , if the calibration is out , sever engine damage will result
Oct 12, 2016 | Diesel Garden
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Hot water heater won't work on gas
check to see if LP section is working check for cobwebs and LP is full and if other LP devices work if not LP problem
Apr 14, 2013 | Lance 2011 Travel Trailer 1685
96 volvo 850 won't start and horn and turn signal chirp on and off
My wife ran into this problem one day when she came out of a store. Turns out the car alarm had been set off in her absence, and the alarm system had immobilized the car. The solution was to simply use the remote (rather than the key) to unlock the car. That cleared the immobilizer, and she started it up and drove off.
Feb 13, 2013 | 1996 Volvo 850
Suzuki gs 850 won't turnover unless jumped
Replace the battery would be my guess.
Oct 11, 2012 | Motorcycles
Won't light no gas
Is the gas supply valve open? the handle will be perpendicular the the pipe if it is on. Is your supply natural gas or LP gas. If LP make sure the tank is supplied. Any LP supplier will be able to check it out. By law they will have to check for leaks before filling the tank.
Oct 06, 2012 | Dayton (4LX430 Gas Heater
I could do with finding the part number for the optical engine for the lp-850. Can anyone point me in the right direction please?
I presume you mean bulb. ?
Ebay item 270635535178
Not cheap and you will need to be handy to take it apart and fix.
Feb 05, 2011 | InFocus LP 850 Multimedia Projector
I won a 1997 volvo 850 and i just got it from
You can get the code from the dealer with the VIN# and you have to pull the radio out to get the radio's serial number. If you've tried too many wrong codes the screen will show error message. If so - disconect the battery for about 60 minutes to clear error message then reconnect and enter correct code
May 09, 2009 | 1998 Volvo S70
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
InFocus LP 850 Multimedia Projector Logo
142 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
