Question about Delta & Single Handle Shower Faucet
RECENTLY THE WATER TO THE HOUSE WAS TURNED OFF, AND AFTER IT WAS TURNED BACK ON THE WATER WORKS NORMALLY EVERYWHERE BUT THE SHOWER. I HAVE A SEPARATE SHOWER WITH A SINGLE HANDLE ON/OFF CONTROL AND A KNOB TO MIX THE HOT AND COLD.
  • 6,674 Answers
Unscrew the shower head and check flow without it on. I'm thinking that debris has plugged up the screen, etc in the head.
Posted on Sep 10, 2010
What could cause the loss of hot water pressure in sink and shower but works fine everywhere else in the house
A calcium build up in the nozel heads or pipes from some not so lovely water. Did it happen gradually? There is a filter in the side of electric hot water systems that needs replacing once in a while but that would affect all the pressure.
Feb 26, 2015 | Home
I went to take a shower this morning and the water was ice cold. For more than twenty minutes the water ran and never warmed up. Are there common things to check my hot water heater for in this situ
There is an adjustment knob to control how hot the water can become. There might be a problem at the tap (however, if this is the case, you would still get hot water everywhere in the house). If the entire house isn't getting hot water, and the knob is set at the hottest water, you probably need to get the hot water tank replaced.
Feb 04, 2015 | Rheem Tankless Hot Water Heater...
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
Water temperature fluctuates with tankless
Have you ever tried to pump water for a fountain... It is so tough and you need larger and larger pumps to get it to go 7 feet high to let's say 10 feet high. Having the on demand water heater in the attic dramatically drops it's pressure. It's best to feed it with a 1 inch or at least 3/4 inch pipe downstairs before it splits the hot and the cold to get the best pressure everywhere then the least pressure will be when it reaches the 2nd floor. but the heater won't cut out because the pressure it even greater downstairs.
Nov 30, 2013 | Rinnai Water Heaters
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I jhave in my showers the Moen and One handle tub and shower faucet, model # T3132. When I turn it on in the showers, there is no hot water... in both it gives me only cold water... even if I turn the...
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Dec 21, 2010 | Moen & One Handle Tub & Shower Faucet
Only hot water/ little pressure
You must of turned off your water to the house or maybe it was turn off in the street recently because it sounds as if you have debris in you strainer remove the head and rise of removing any dirt rise out both front and back of shower head while head is off run shower to make sure you are getting full pressure out of the pipe that the head is connected to
Jul 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Delta & Single Handle Shower Faucet  Logo
173 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
